Question about NComputing Computers & Internet
I have a three-user nc360 system.currently, its displaying the message "internal error " on the other stations except the host.please help
  • 130 Answers
SOURCE: System Error message
So you have any other memory cards? You may want to try that first. What batteries are you using? Can you try a new set of NiMH batteries? not alkalines but NiMH try these things first because they are easy. If you have tried different memory, and different batteries then it could be a connection problem inside the unit. These cameras dont have may circuit boards so they use ribbon cable to connect the different componets together. These can sometimes work loose. An impact can vibrate them just enough to cause the problem. It could also be the lens mechanism. Sand and grit can work into the gears and bind them up. If it zooms in and out smoothly then this maynot be the problem. If you hear any change in the speed of the motor when its zoomed in and out that could be it.
Posted on May 06, 2006
  • 186 Answers
SOURCE: Internal Error
what is the error on the copier screen. does it copy ok?
Posted on Jun 21, 2007
  • 208 Answers
SOURCE: cant get rid of blinking error message, nothing works
  1. Find the pink Clear button on the Control Panel.
  2. Find the button below the word Auto. Under image quality
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.It may be clear Copy quality, or image quality
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 05, 2007
  • 4234 Answers
SOURCE: Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Posted on Jul 15, 2008
SOURCE: system date error! please check NDS system date.
I have a tempory method of fixing it!
  • Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
  • Done!
Although this temporary the people at NDS are working for a solution i think. But until then you might just have to keep putting the date back.
Posted on Apr 14, 2010
What is the traffic button for in a 2002 alero
According to the owners manual
TRAF (Traffic): Press this button to receive traffic announcements. The traffic announcement brackets will appear on the display. TRAF will appear on the display if the current station broadcasts traffic announcements. If the current station does not broadcast traffic announcements, the radio will seek to a station that does. When the radio finds a station that broadcasts traffic announcements, it will stop. If no station is found, NO TRAFFIC will appear on the display. When a traffic announcement comes on the current radio station or a related network station, you will hear it, even if the volume is muted or a compact disc is playing. If the compact disc player was being used, the compact disc will stay in the player and resume play at the point where it stopped. INFO (Information): If the current station has a message, INFO will appear on the display. Press this button to see the message. If the whole message does not appear on the display, parts of the message will appear every three seconds until the message is completed. To see the parts of the message faster than every three seconds, press this button again. A new group of words will appear on the display. Once the complete message has been displayed, INFO will disappear from the display until another new message is received. Hope this helps.
Feb 25, 2014 | 2002 Oldsmobile Alero
Stations stopped it says internal error .NCX-2000-xp
1. display message as updating service
2. while updating service error display already registered yr serial number
Jul 14, 2011 | NComputing X300 3 User Expansion Kit...
NComputing vSpace not installed my pc Error
Options:
(A)
An authorization error usually occurs when more than one system in a LAN has the same software serial numbers assigned to the system. In this case, the first PC to be turned on does not suffer an authorization error, but any subsequent PC's which contain the same serial number will experience the issue.
To remove these duplicate serial numbers, first unregister them, then delete them from the host PC they are installed on:
  1. Access the NConsole application by either:
    • Click "Start" > "All Programs" > "NCX-2000-XP" > click on the entry labeled "NCX - 2000 - XP"
    • Double-click the NComputing console application icon in the system tray
  2. In the left-hand pane, navigate to "Local Settings" > "Information and Settings" > "Serial Numbers"
  3. To unregister a serial number, right-click on the number and select "Unregister now"
  4. To remove serials, right-click on the number and select "Delete"
Also, an update that does not install correctly may rarely cause corruption of the data file in which serial number information is contained, causing this error. If there are no other X-series hosts on the network with duplicate serials, then a complete uninstall and reinstall of the X-series software may fix this issue. When uninstalling, choose to unregister all serials and remove all serial registration data.
To download the latest version of our software, please search the knowledge base using "software download" as the search text, for links to the latest software.
(B)
When more than one X300 station is used under the same login (same Username on two or more stations), Active Desktop error messages may occur. Also stations would be sharing same user settings and other files, which could cause unpredictable errors.
Different stations should always be used with different usernames logged in. To add more User accounts (usernames), go to Windows Control Panel, select Users and then go to Create New User option.
Mar 10, 2011 | NComputing X300 3 User Expansion Kit...
Received the followin ERROR: log_id 32485569 ORA-01013: user requested cancel of current operation. i restarted and received the same message except it was log_id 32486390. i therefore could not...
What are you registering to or what are you doing to get this message? This would assist to know the process of what you are doing to get this message. Please let me know or maybe someone will see and recognize what these mean. Is it a blue screen showing this during an install of operating software. Curious? John
Jan 15, 2011 | Computers & Internet
550 NCOMPUTING PROBLEM
when i insert ncomputing cd in my computers drive and want to install ncomputing softwere the massege appearce that "NComputing vSpace not installed
Error report:
This software is hardware protected. Your hardware is not supported. Please contact NComputing Inc. or its partners to purchase supported hardware. plz solve my problem as soon as thank u
Jul 16, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Spectralink PTB400 internal error
Correcting Spectralink Errors Below are instructions on performing a “soft test” which will correct any internal error 8 and 4444-444C messages on your Spectralink phone. To aid you in educating your staff you may view the following Word document showing the step-by-step instructions. Please feel free to print and post this document where the Spectralink phones are kept on your floor. Soft Test Instructions
  1. Power off the phone.
  2. Press and HOLD the volume key (VOL) and the power key at the same time (the phone will chirp and display the serial number.)
  3. Now…release ONLY the power key (phone will vibrate and make a long tone.)
  4. Now release the volume key (the display will have a lot of black boxes and ZZZZ’s – you will also see the bottom of the display showing “msg”, “bat”, etc.)
  5. Count to three and then power off the phone.
This “soft test” is to correct only certain internal error messages. When the phone is experiencing a correctable error the display will read “internal error 8” or “internal error 4444-444C”. For all other internal errors the phone will need to be taken to Teleservices, NE-165 to be replaced.
As per : http://depts.washington.edu/uwmcdir/spectralink.html
Mar 16, 2010 | Spectralink (PTB400)
I keep getting the message 2010
After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
Solution There are three possible workarounds to eliminate the error:
  1. Update the hard drive firmware to the latest level. Download the hard drive firmware update, and then apply to your hard drive.
    Note: This update requires a floppy disk drive.
  2. Replace the hard drive with one supported by the system being used.
  3. Use the hard drive, producing the 2010, error in the Ultrabay of the system or a docking station with the second hard drive adapter instead. The interface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potential problems with diagnostic or copy tools. There are known issues with several of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided by Hitachi GST which uses vendor specific commands on the hard drive. These may not be correctly interpreted since they must pass through the serial to parallel ATA bridge. However, version 4.00 or later of the Disk Fitness Test (DFT) will work.
  2. HDDTEST version 0.28 by Hitachi GST does not function properly for similar reasons. Instead, use HDDTEST version 0.29 or later.
  3. DOS-based copy tools may function slowly or produce incorrect output, specifically previous versions of Norton/Symantec Ghost. These versions are not compatible with the Serial-ATA interface of the Intel ICH6M chip set. Documentation on this problem may be found at www.symantec.com. It is recommended to use either a newer version of Ghost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost 8.0 or later, or to use the -FNI switch when invoking Ghost from the command prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. The hard drives shipped in the affected systems will not display the message because they already have firmware that recognizes this new Serial ATA bridge chip. However, a similar drive from an earlier ThinkPad system or an OEM drive might cause the error message to be displayed. Customers may also notice the POST error message after applying a ThinkPad BIOS update if a drive without the firmware update is installed in the system. Some early systems were shipped with a system BIOS version that did not provide this POST error message. Updated BIOS has been released to provide this informative POST error message to users.
Apr 30, 2009 | Computers & Internet
Error Message - Failed to get data for SchemeAC
This is generated by a program that is run at start-up and it is being denied access to a resource due to the permissions of the user. As long as it isn't a critical app (probably isn't), you can just ignore it or if your feel courageous, you can investigate by downloading autoruns.zip from the Microsoft website. It is a utility developed by SysInterrnals (bought by MS s few years back) that will display every program that starts up through entries in the registry, start-up files (autoexec.bat), and a host of other ways. By going to the Logon tab, you can see what was started when this user logged into the system. Look for anything that says SchemeAC and disable it. Log out and login again. The error message should not appear. This needs to be done for the current user only, not the Administrator.
Mar 26, 2009 | Acer Aspire 1681WLMi Notebook
Display 2010 error message
POST warning message 2010 after BIOS upgrade or hard drive installation - ThinkPad General
dblue_rule.gif c.gif d_bold.gif Applicable countries and regions c.gif dotted_rule_443.gif c.gif Symptom After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010:Warning: Your internal hard disk drive (HDD) may not function correctlyon this system. Ensure that your HDD is supported on this system andthat the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
Affected configurations This message may occur on any system that uses the Intel 915 Expresschip set. This new chipset uses a different hard drive interfacetechnology (Serial ATA) to address the hard drive. Models specifically included are of the following systems:
  • ThinkPad R52 systems
    Machine types:
    • 1846, 1847, 1848, 1849, 1850, 1858, 1859, 1860, 1861, 1862, 1863, 1870
  • ThinkPad T43 systems
    Machine types:
    • 1871, 1872, 1873, 1874, 1875, 1876, 2668, 2669, 2678, 2679, 2686, 2687
  • ThinkPad X41 systems
    Machine types:
    • 1864, 1865, 2525, 2526, 2527, 2528
  • ThinkPad X41 Tablet systems
    Machine types:
    • 1866, 1867, 1869
  3. Usethe hard drive, producing the 2010, error in the Ultrabay of the systemor a docking station with the second hard drive adapter instead. Theinterface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potentialproblems with diagnostic or copy tools. There are known issues withseveral of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided byHitachi GST which uses vendor specific commands on the hard drive.These may not be correctly interpreted since they must pass through theserial to parallel ATA bridge. However, version 4.00 or later of theDisk Fitness Test (DFT) will work.
  3. DOS-basedcopy tools may function slowly or produce incorrect output,specifically previous versions of Norton/Symantec Ghost. These versionsare not compatible with the Serial-ATA interface of the Intel ICH6Mchip set. Documentation on this problem may be found atwww.symantec.com. It is recommended to use either a newer version ofGhost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost8.0 or later, or to use the -FNI switch when invoking Ghost from thecommand prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. Thehard drives shipped in the affected systems will not display themessage because they already have firmware that recognizes this newSerial ATA bridge chip. However, a similar drive from an earlierThinkPad system or an OEM drive might cause the error message to bedisplayed. Customers may also notice the POST error message afterapplying a ThinkPad BIOS update if a drive without the firmware updateis installed in the system. Some early systems were shipped with asystem BIOS version that did not provide this POST error message.Updated BIOS has been released to provide this informative POST errormessage to users.
Jan 07, 2009 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
23 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
