Question about Samsung Sme-4221n 8 Channel Lcd Dvr System, 4 Ir Cams
Sme-2220n dvr no signal
All that shows on screen is dvr no signal
DVR Video Loss
Charter was out and changed modems, after that I noticed we lost signal.
Aug 16, 2012 | QPS Q-See QSDR008RTC-500 8 Channel H.264...
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
TV is hooked up to Time Warner DVR when I turn on the TV it shows searching for signal but will not allow me to change channells
It will not let you change channels until the signal locks on. If it just keeps searching for the signal, look for a reset button on the dvr. If not, pull the power for 20 seconds to reset the dvr. IF it still wont find a signal, there is a major problem and you should call your satellite provider.
Aug 09, 2010 | Haier Televison & Video
There is sme problem wh ma laptop wen i am
If the screen shows a picture but very faintly, the inverter is either not connected properly or faulty.
If there's nothing on the screen at all
1) Your screen is either not connected properly or faulty.
or 2) *********** board has a fault.
or 3) Your graphics card/chip has a fault.
You can connect your laptop to another screen using the VGA port on the back. You have to switch to the spare screen using the keyboard, usually Fn and another key. If the spare screen then shows a picture, *********** board and graphics card are OK, your screen is at fault or not connected properly.
Checking the connections to both the inverter and screen will require dismantling you laptop. If you go about this, ensure all power, including the battery is disconnected.
Apr 26, 2010 | HP Compaq Presario V2000 Notebook
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Sep 05, 2009 | DISH Network DVR-625 DTV Receiver /...
Prior to the recent installation of Direct TV I was with DISH. I switched to Direct when Dish attempted to charge me for a new full package cost because I wanted to re-activate a Dish receiver which I had...
After it is hooked up, it should have a white screen saying "searching for satellite signal." After fifteen or twenty minutes, it will go to a black screen saying the same thing in a blue box. Once you are there, you can prerss the LIST button on the remote and record and copy your selected shows. This is assuming you have a newer DVR. Model R15 or higher. thanks keep updated
Jun 16, 2009 | Philips Televison & Video
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
Dvr stuck on ''receiving satellite info'' when reset.
When it's rebooting, on the first blue screen press 02468 on the remote. This will force a software update. If you have trouble getting it enter at the right time or you just want to make sure, just keep pressing 02468 until it goes to the update. It won't hurt any thing. Hope this helps.
Mar 18, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
Shows canceled?
Make sure u have signal on both tuners on the DVR ( check it in your set-up screen). both tuners should have the same siganl strength. Directv's DVRs, if installed correctly, give u the option of recording one channel and watch another, or recording 2 seperate channels( 2 tuners). If you are recording 2 seperate shows and u change the channel one of your recordings will cancel .
Sep 13, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Samsung Sme-4221n 8 Channel Lcd Dvr System, 4 Ir Cams Logo
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
