Question about Kitchen Appliances - Others
Where can I download instructions for utilitech 15 amp mechanical residential timer.
    New Friend:
    Problem Solver:
  • 6 Answers
Http://pdf.lowes.com/operatingguides/827214004552_oper.pdf
This is from lowes and it is not pretty, but it has everything on there. It is the original document before being printed on a large sheet and folded multiple times so it has markings for the cuts and folds.
Posted on Mar 16, 2016
How do I program a Utilitech timer UTTNOCD2(154182)?
Lowe's has the instructions for the UTTNOCD2 (154182) on the product page: https://www.lowes.com/pd/PRIME-15-Amp-2-Outlet-Mechanical-Residential-Plug-in-Countdown-Function-Lighting-Timer/4177013 . Expand the Guides & Documents section. The direct link to the instructions is http://pdf.lowes.com/useandcareguides/054732816729_use.pdf .
After plugging in the timer, you need to rotate the black dial (clockwise or counter-clockwise) until the desired setting is lined up with arrow (at about 11 o'clock on a 12 hour analog clock). The choices are On, Off, On at dusk for the desired number of hours (even number of hours), or On at dusk and Off at dawn.
I hope this helps.
Dec 07, 2017 | Hardware & Accessories
I need the English instructions for the Utilitech timer #0144506
I found a Utilitech timer at Lowes with the item number #0144506. The Utilitech model number for this timer is UTTNID001. If this is the correct timer, the manual is on the product page: https://www.lowes.com/pd/Utilitech-15-Amp-1-Outlet-Digital-Residential-Plug-in-Lighting-Timer/4740850 . Scroll down and expand the Guides & Documents section. The direct link is currently: http://pdf.lowes.com/useandcareguides/054732817825_use.pdf .
I hope this helps.
Nov 23, 2017 | Hardware & Accessories
I need directions on how to program my Utilitech 15-amp 6-outlet digital lighting timer
If possible, return to the place of purchase and find out whether they will make a copy of the instructions for you.
Dec 10, 2014 | Hardware & Accessories
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 29, 2013 | Hardware & Accessories
Need utilitech 0050024 instructions
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#0050024
Nov 26, 2012 | Hardware & Accessories
THIS SITE KEEPS POSTING ANSWERS THAT ARE TOTALLY UNRELATED TO MY QUESTION
Try posting your question in a more appropriate area of FixYa. From what I can tell, you're asking about a porch light timer of some type. You've posted twice in the "Cars & Trucks" area and three times in the "Digital Cameras" area. Your questions are seen by experts in those areas, none of whom may know anything about porch light timers.
Aug 29, 2012 | Cameras
Can I install a utilitech Dusk-to-Dawn light control, #0314355 in a 'horizontal' position, rather than the 'vertical position shown on the packaging? It goes 'on-and off' in a 15 s
Timer is probably wired incorrectly.
Copy following links for correct wiring, and larger instructions.
I have tested this timer, and some problems can also be caused by overlapping and conflicting programs: reset timer and review timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 31, 2012 | Hardware & Accessories
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 30, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
2,350 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
