Question about ViewSonic Televison & Video
No backlighting KM19002DVD-07
The fuse on the backlighting board was blown so I have replaced it but still no backlighting.
    Top Expert:
  • ViewSonic Master
  • 74,251 Answers
If the fuse should blow up, surely there will be a reason for that. Any short circuit, overload etc: Check it. It is best to replace the back-light inverter board, rather than making "surgery" to it. For more information go to http://electronicshelponline.blogspot.com/
Posted on Nov 27, 2013
How do you fix a Samsung 55" Television with no picture but good sound?
The symptoms you described would indicate the backlights are not working.
The 2 main reasons are the backlight inverter board has gone or the backlights have blown!
Since you have replaced the inverter board with a new working one then this would point towards the LED backlights.
Apr 02, 2016 | Samsung Televison & Video
There is no picture on bush 26inch flat screen tv
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.If otherwise,
You most likely have a backlight issue with this TV set. Could be the inverter circuits for the backlights. The inverter is the power supply source for the backlights. there could also be a screen driver problem.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help in solving the problem....
Jun 14, 2011 | Televison & Video
Backlight repeatedly turns off
Replace the backlight.
Google your make and model, lots of places selling replacements
Jul 31, 2010 | Belinea 10 15 55 15" LCD Monitor
Blown fuse on a ilpi-009 power supply
hi, i don't know the exact power board you speak of, most fuses for power supply protect ac inboard power, and backlights. if backlight inverters touch ground or ground out, this will blow fuse. otherwise, the fused circuit is used for main inboard power going to primary capacitor. take an automotive fuse holder and solder test leads long enough to work with, install 4 amp blade fuse and jumper/solder the circuit to the fuse on the board and power on the monitor. if all goes well, probably just power surge or outlet grounded. if blows fuse, check to board for obvious burns or blown capacitors. if not there, unplug backlights and power on, if still blows, check to make sure no direct conact with board and back of screen. just be thorough about looking carefully for shorts if there is one. and don't forget to replace the factory fuse on the board with the correct one after you finish repairing, don't leave that automotive fuse in. good luck.
May 10, 2010 | Emprex LM2201 22" LCD Monitor
May a pop noise, now no picture but has sound. it is a Hitachi 42 in. plasma tv mod. 42edt41a
Sounds like the Invertor for the backlights has blown. if you are lucky and it is just the invertor blown it could cost £50-£150 for a new invertor board, but if you are unlucky then the backlights themselfs have blown too which means the TV is beyond economic repair.
Apr 05, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
50 inch vizio, no picture but theres sound!!
check y-sus board(top left with 2 white fuse)
check z-sus board(right small board with 2 white fuse)-view from back
blown fuse? replace that board. partstore.com or discount-merchant.com
Aug 05, 2009 | V, Inc. Vizio P50HD Plasma Television
Has sound, the backlight works but no picture.
here is a fuse on the on the t-conn board .it is where the lvds cable connects .it is blown.
Mar 17, 2009 | Philips Televison & Video
Possible backlights not working
Unfortunately the cause is normally the screen itself or the inverter board
May 18, 2008 | Computers & Internet
Need new power/invertor board for Acer AL1711
R1 will be blown, replace it with a 10 ohm resistor. Also replace C6 and C22 with 220uf 25v Capacitors.
Dec 11, 2007 | Acer AL1711 17" LCD Monitor
Open Questions:
Televison & Video Logo
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
