Question about Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet
Ricoh direct IT HAS A RED LIGHT ON AND IT DOESNT WANT TO PRINT,ON THE SCREEN IT SAY SC(28212)
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Posted on Mar 02, 2009
  • 192 Answers
SOURCE: i HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Posted on Nov 19, 2009
santosj27
  • 263 Answers
SOURCE: SC550 Error. Ricoh MP
That error code refers to the FUSING WEB END.
First of all you must see if the fusing web is end.
If the error occurs before the web ended you have to upgrade your firmware. There is a release firmware that corrects this symptom.
Posted on Feb 23, 2011
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Ricoh Error SC899
SC 899 is a software error. For example printing from directly from a website. Various printing from websites makes 899 error. Just remove the print queue from the computer and that's it. Make sure you save the file first from the website before you print to avoid same problem.
Aug 11, 2014 | Ricoh Aficio Office Equipment & Supplies
Ricoh SG-3110DN 28212
use a web browser and type in IP address at top and problem will be displayed
Nov 18, 2013 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP 2501SP How do I print the SMC
, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change go to direct sp and push 5990 then enter (#)
Sep 21, 2013 | Ricoh Aficio Office Equipment & Supplies
Whats error code sc 28212
Turn off printer remove carts wait 2 minutes but back in and turn on!
Oct 30, 2012 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
My brandnew Ricoh is saying Error SC 28212 ~ What does this mean??
Call sawgrass tech support for the reset.... it is straight forward and easy to follow. As per customer support, you will need better than 20% full cartridges, they recommend new ones, which they will provide overnight free if still warranted.(ERR28212) As discussed, here are the reset instructions.
1. Turn the printer off.
2. Open the cartridge door and leave it open until step 15.
3. Turn the printer back on.
[img id="Picture_x0020_1" alt="3110 Panel" src="file:///C:/Documents%20and%20Settings/Nancy%20Smith/Local%20Settings/Application%20Data/IM/Runtime/Message/%7B944CD05A-8C76-404B-84B9-E5D3FB8CED31%7D/Show/image0011.jpg" width="500" height="143"> (was a photo of machine front, the down button is also "menu")
4. Hold down both the Up & Down arrows together for 3 to 5 seconds (nothing on the LCD display will indicate the appropriate amount of time has passed)
5. Release the arrow buttons and press #Enter (if nothing happens, try again)
6. When successful the LCD will display SYSTEMver with 3 optional menu selections starting with Service Menu
7. Press the down arrow once to Engine Maint. and press #Enter
8. The LCD will display SP No. with the default 1000000 underneath
9. Using the Up & Down arrows, and pressing #Enter after each number, enter 3009002. Press #Enter when complete.
10. CARRIAGE CHANGE 3009002 will display on the LCD. Press #Enter.
11. CARRIAGE CHANGE EXEC will display on LCD. Press #Enter.
12. OK? will display on the LCD Press #Enter.
13. Then Running will flash on the LCD panel before going back to CARRIAGE CHANGE EXEC. Continue to next step.
14. Exit the SP mode by pressing the Escape button repeatedly until you are back at the Engine Maint. screen. Press the down arrow once to End. Press #Enter one more time to completely exit.
15. Turn the printer off.
16. Replace the four ink cartridges with new ones.
17. After the new cartridges have been installed, close the right front cover.
18. Turn the printer on.
19. Wait for the machine to fill go through an initialization procedure which may take about 7 minutes.
This 100% worked for me.... be certain that the screen displays EXACTLY what the directions tell you!! -NSmith
Aug 07, 2012 | Office Equipment & Supplies
My printer ricoh 2045 show an error sc 302,not print image correct
i have an error on my printer sc 302 how i can clear it easily .printer is ricoh 3045
Aug 11, 2011 | Ricoh Computers & Internet
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet Logo
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
