Question about Ricoh Aficio Office Equipment & Supplies
Ricoh SG 3110 DN
MY ricoh printer is not printing,on the screen it says power off on SC (28212)DONT KNOW WHAT IT MEANS AND IT HAS A RED LIGHT ON
drichards
  • 87 Answers
SOURCE: RICOH AFICIO SP C411 DN COLOUR LASER PRINTER
Open the side cover, and unlatch the plate. The PCUs are located in there. In the replacement PCU, there should be instructions.
Posted on Apr 01, 2008
KOakaKO
  • 135 Answers
SOURCE: SC 329 code Aficio 550
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the “Enter” key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Posted on Dec 12, 2008
  • 126 Answers
SOURCE: ricoh sc 551
This is a fuser temp. problem -- must reset and/ or replace thermistors.
Press clear modes button then 1-0-7 then hold down the clear stop button.
When display changes touch copy sp modes.
Turn may power off and wait about 30 sec.
Turn power on.
If the machine comes to ready you are ok for now.
If code returns you must replace thermistors.
If you need to replace thermistors, contact me and I will get you part numbers and instructions.
Posted on Jan 16, 2009
SOURCE: Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Posted on Mar 02, 2009
  • 393 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
My printer it takes out dirty paper where should i clean it aficio SG 3110 DN
Sounds like developer power is bad need to replace developer unit or photo conductor unit if combine as one unit.
Mar 22, 2017 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
How to fix the error sc 20220
If the error you are talking about is SC202, then you have a laser problem. You will need to either replace the Polygon Mirror Motor or the complete Laser Unit if it comes as one assembly.
Jun 14, 2016 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
57000 error
hi
please my SG 3110DN printer came up with this error code : SC 57000
Jan 06, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Sc (28112) error
I have a ricoh SG 3110 DN error code 28112. Can I fix this?
Dec 07, 2013 | Ricoh Aficio Sg 3110Dnw 29Ppm
Ricoh SG-3110DN 28212
use a web browser and type in IP address at top and problem will be displayed
Nov 18, 2013 | Ricoh Office Equipment & Supplies
Ricoh SG 3110dn, SC 20200
you need change ink collector unit.
Sep 16, 2013 | Ricoh Office Equipment & Supplies
Whats error code sc 28212
Turn off printer remove carts wait 2 minutes but back in and turn on!
Oct 30, 2012 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
My brandnew Ricoh is saying Error SC 28212 ~ What does this mean??
Call sawgrass tech support for the reset.... it is straight forward and easy to follow. As per customer support, you will need better than 20% full cartridges, they recommend new ones, which they will provide overnight free if still warranted.(ERR28212) As discussed, here are the reset instructions.
1. Turn the printer off.
2. Open the cartridge door and leave it open until step 15.
3. Turn the printer back on.
[img id="Picture_x0020_1" alt="3110 Panel" src="file:///C:/Documents%20and%20Settings/Nancy%20Smith/Local%20Settings/Application%20Data/IM/Runtime/Message/%7B944CD05A-8C76-404B-84B9-E5D3FB8CED31%7D/Show/image0011.jpg" width="500" height="143"> (was a photo of machine front, the down button is also "menu")
4. Hold down both the Up & Down arrows together for 3 to 5 seconds (nothing on the LCD display will indicate the appropriate amount of time has passed)
5. Release the arrow buttons and press #Enter (if nothing happens, try again)
6. When successful the LCD will display SYSTEMver with 3 optional menu selections starting with Service Menu
7. Press the down arrow once to Engine Maint. and press #Enter
8. The LCD will display SP No. with the default 1000000 underneath
9. Using the Up & Down arrows, and pressing #Enter after each number, enter 3009002. Press #Enter when complete.
10. CARRIAGE CHANGE 3009002 will display on the LCD. Press #Enter.
11. CARRIAGE CHANGE EXEC will display on LCD. Press #Enter.
12. OK? will display on the LCD Press #Enter.
13. Then Running will flash on the LCD panel before going back to CARRIAGE CHANGE EXEC. Continue to next step.
14. Exit the SP mode by pressing the Escape button repeatedly until you are back at the Engine Maint. screen. Press the down arrow once to End. Press #Enter one more time to completely exit.
15. Turn the printer off.
16. Replace the four ink cartridges with new ones.
17. After the new cartridges have been installed, close the right front cover.
18. Turn the printer on.
19. Wait for the machine to fill go through an initialization procedure which may take about 7 minutes.
This 100% worked for me.... be certain that the screen displays EXACTLY what the directions tell you!! -NSmith
Aug 07, 2012 | Office Equipment & Supplies
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
57 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
