I have a faulty Trane Thermastat TAYSTAT302c and
I have a faulty Trane Thermastat TAYSTAT302c and i need to disconnect the heating and run the cooling. The wire schmatic is confusing. Which wires need to be connected to run the cooling only.(the heating is running continuously)and i need to disconnect the wiring for the heating.
  • 148 Answers
Take the w terminal wire off
Posted on May 08, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
I am trying to install the new tx900ts in my house and i do not understand the wiring on it i have a old trane thermastat that has different wiring codes
PLEASE GIVE ME A RATING AND VOTE YOU NEED TO FIGURE YOUR WIRES WRITE IT ALL DOWN AT UNITS AND THE OLD STAT
common is different by installer so you gotta look at the units or you will blow out your transformer this wire will be blue or brown
24v always red
compressor always yellow
fan always green
reversing valve always orange
heat w1 always white
emergency heat will be either brown or black dependinting on installer if its a heat pump this it what you have but if its a gas system its much easier
red- 24 volt with a jumper already on the new stat
white- heat w terminal
yellow- cool y termina
fan green- g terminal
and common is optional with batteries so its not needed
if you need further help email pendletonheatandair@hotmail.com
Sep 20, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Electric furnace. Just replaced the controller board but no heat. The blower does come on when the thermostat gives the heat command and I was wondering if that means the relays to the furnace coils is...
On a Trane furnace the fan realy must energize before the electric strips will come on. On the thermastat. See if there is setting for electric heat. This will bring the fan on and the strips should come on. First just turn on your heat and and turn fan to on postion if it works you need to set tstat to electric heat mode. Most of the time there is sswitch in the back of the stat that says gas elec. Turn to electric. Rus
Oct 29, 2009 | Heating & Cooling
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
No heating, cooling or fan.
I'm confused. You have a Trane, but are asking about the Goodman warranty. I missed something there I'm sure, sorry.
"IF" Trane has a recall or warranty issue, then any qualified technician should be able to help you with that. The parts would be provided by trane in such an event, but unless the unit is less than 1 year old, chances are you will have to pay for the labor.
Being an electricain help if you want us to assist you in troubleshooting.
This link takes you to the TRANE contact page. They can answer any warranty/recall questions you have.
Jan 21, 2009 | Heating & Cooling
Cooling fans would not turn off and i found that the thermastat was bad i disconected battery replaced thermastat filled the radaitor with antifrezze reconected battery started my caravan and now the fans...
when you disconnected the battery, the CPU (computer) modulke got de-programmed. disconnect the negative cable from the battery. Wait a minute then reconnect. you may have to do this several times.The purpose is to reprogram the computer.
Dec 19, 2008 | 1999 Dodge Caravan
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
