Question about Iomega 32927 35 GB Hard Drive
Iomega Rev 35 Repair
I have a Iomega Rev 35 that will not power up. I tried other outlets and other USB ports but no luck. It is out of warranty so  Iomega will not take it back. Any idesa???  Help
  • 1 more comment
  • maxaron Dec 04, 2007
    Same problem here with Rev 35 drive. I'll toss it out. The 400,000 hour rating is B...S...! The expensive discs can follow it into the junkpile.
    Jack
    jcohen@elicohenrealestate.com
  • ms53 Jul 22, 2008
    I went to check the last backup and was surprised to find the disk had ejected. I reinserted it and tried to browse to see if files had been updated, but Windows could not find the drive. Tried a different disk and it was immediately ejected. (I think the lighted button was flashing the whole time.)
    The next morning, the light was off, the power supply felt hot. Took it to a different outlet, different computer, but it's completely dead now.
  • Anonymous Mar 19, 2014
    I NEED A USERS MANUAL FOR THE IOMEGA RDHD DISC.
A new power supply does the trick.
Posted on Dec 16, 2008
  • 4 Answers
Care to sell me the parts?
mr_bill at Mailcity dot com
    Scholar:
  • 116 Answers
Those are not really servicesable parts in that sucker. Do you get anything at all when pluging it in?
If not you should try a new pc. Still nothing?
May want to search ebay for a cheap replacement.
Posted on Oct 11, 2007
Iomega external hard drive is not detected. previously it was working fine on my laptop. so i guess it has usb v2. but after i got it repaired for motherboard problem it stopped detecting my external hard...
Hi - Does your laptop have more than one usb port? If so try the drive in it/them. Also, try another device (mouse, etc.) in the USB port(s) and see if it works.
The drive probably (you didn't say which model so I'm not sure where). has a power led somewhere. Does that light up when the drive is plugged into the notebook? If not that would certainly be cause for it to not be recognized.
Lastly, you didn't specify which notebook you have so I can't tell you how to; but upon bootup get into the BIOS setup menu and check any settings for USB and storage devices - don't do this if your not comfortable with it or haven't done it before.
If nothing else works in the USB port(s) it would point to possibly something done while in the repair shop that was an accidental no-no.
Good Luck, Mikeywaf
Mar 03, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
My iomega 320gb hard drive is just beeping when it's plugged in. I've tried plugging it into other computers, trying different USB ports, uninstalling it from my computer then letting it reinstall...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 25, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
I have an iomega portable hard drive USB 2.0 called eGo. I have been using it with my Macbook. Since yesterday my computer does not recognize my eGo. I have tried to change the USB ports, have restarted...
* the USB cable
* the power-adapter
Dec 11, 2010 | Iomega eGo Portable Hard drive 500 GB ...
My PC cannot see the hard drive
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
External iomega usb drive fails to mount. was working fine. moved my computer station, detaching everything and just got everything set up. Tried: different usb cord, different usb port, different...
It could be that for some reason it is trying to grab a drive letter that is already being used. As administrator, right click on "My Computer" > Manage > Disk Management. Change the drive letter if needed by choosing "Edit". (You should first check your iomega by connecting it to another computer to make sure it is working properly.) Good luck.
Nov 28, 2009 | Office Equipment & Supplies
Pen drive not getting detected? how to work it?
first go to my computer propery then hardware then device manager then go t ousb controller uninstall all usb drivers from there then just right click on any driver then click on scan for hardware changes then it automatic install usb drivers .
Connectyour pen drive to usb port check all port.
then if its not working check with other usb device is working with usb port?
Jul 15, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Retrieving data off Iomega 35 GB Rev Disk
send me the old drive and cartilage. I will get the data off and put it on dvd's and send the dvd's back to you and keep the drive and cartilage for parts. I have several rev 30's and rev 70'S.
mr_bill at mailcity dot com
Jun 04, 2008 | Iomega REV Tape Drive
Cartridges will not stay in & cannot see the device in 2003 enterprise
Turns out the PSU unit was weak. It couldn't provide the power needed to spin up the disks when inserted.
Problem Solved.
Apr 06, 2008 | Iomega REV Tape Drive
I have Iomaga Rev Drive About 3 Years old lights up doesn't Work Is there repair available? Qprint@hiwaay.net Thanks, Terry at The Quickprint Shop
Iomega does do out of warranty repair.. BUT it seems to take them for ever...
In Warranty (Without a Rapid Response service plan)
  1. Regular Hours: Monday - Friday, 9 am - 10 pm Eastern
  2. After Hours and Weekends: $50 per incident
  3. Phone: 1-800-940-6354
Out-of-Warranty
Be aware there MAY be a fee involved if it is in fact out of warranty Good luck
Mar 07, 2008 | Computers & Internet
Iomega 32927 35 GB Hard Drive Logo
772 people viewed this question
Top Iomega Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Alun Cox
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
