Question about Whirlpool RBS305PDS Electric Single Oven
Oven will not work at all after clean cycle
After a clean cycle, the oven will not get hot at all (in any mode) it will not even go into a clean cycle again.  the control panel is working the same as it did. i can feel air comming out of the front vent (not hot at all)
what do you think the problem is
thanks in advance for your advice.
  • 9 more comments
  • kissle Nov 21, 2007
    After clean cycle oven does not work at all.
  • ikkin Dec 01, 2007
    same problem after doing self clean, i could'nt use my oven anymore
  • Anonymous Dec 10, 2007
    same problem
  • Anonymous Dec 17, 2007
    same problem...did anyone find a solution?
  • ekalb Mar 12, 2008
    i have the same problem after my wife had it autoclean
  • 3yearsold Jun 01, 2008
    Same problem as tkpoolman.  I tried all troubleshooting under "Oven will not operate".  Are there any responses to the other consumers who have had the same problem.  If so, where can I find it?
  • Anonymous Jun 14, 2008
    Oven won't work after cleaning
  • monivargas19 Jun 29, 2008
    Ran the self-cleaning sequence on my whitlpool double oven and has not had power since. Door is lovked, no power what so ver to the unit....I am having a huge party in a week the timing could not be worse...any help appreciated!! Monica
  • jaymeevue Dec 15, 2008
    I have the same problem.
  • Anonymous Dec 17, 2008
    Exactly the same as TK's problem.
  • dcarpenter5 May 11, 2010
    Did replacing the control panel work and if so at what cost $$$?
Im looking for it,
Posted on Nov 05, 2008
Same with mine I was just told it is the control panel needing replacement.... $$$$$$$$$$$$$$
Posted on Dec 17, 2007
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
I cleaned (auto clean cycle) and now there is a beep and F-2 flashes on the panel. Door is in lock mode and still very hot. What does F2 mean?
Means it is sensing that the oven temperature is above 915F-930F. Check the door lock switch.
Feb 28, 2011 | GE Ovens
My oven display has a error display of E5F7,oven too hot.. The doors will not open. They are locked in the self-cleaning mode. How can I open the doors or can I do something to override or reset the the...
This problem is caused by defective material in the core
of the solenoid on the door latch. The solenoid works
properly at normal temperatures, and at the beginning of
a self-clean cycle. However, when heated, the plastic
core binds the metal plunger, and will not allow it to unlock
at the end of a cycle. Once cooled, the solenoid will
again work properly. When a technician inspects the
solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Jan 26, 2011 | KitchenAid KEBC208 Electric Double Oven
Self cleaning hot point will not work
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 24, 2010 | Ovens
Self-clean cycle not working
the first problem may very well be your control board and or as they call it a clock timer.while the unit is in the cleaning mode you need to check the power from the control board to the elements, you may also have
Jan 31, 2010 | Ovens
theres athermal fuse located on the rear of the unit sounds as if its gottren to hot and opened for safety reasons, you see its a quarter sized thermostat with 2 wires leading to it usually on the upper middle of rear cabinet betwwen the broil elemnt hookups, TURN OFF PWER BEFORE CHECKING LIVE WIRES
May 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBS305PDS Electric Single Oven Logo
87 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
