Check the dial pad keys for a stuck button, if it has a hanset with its own dial pad check it as well.
If you can not locate it, try listening on the line and pushing the dail keys one at a time. you should now hear dual tomes, the one you are causing and the offending tone, when you hit the offending key there will onlt be a single tone as this button is already sounding off.Do not forgrt the special keys(# &*)
The paper is not feeding through the fax machine when a fax comes through because a rod (bar with a...
(More)
The paper is not feeding through the fax machine when a fax comes through because a rod (bar with a wheel (roller) on the end came off from the inside of the machine. I found the slot it came from but when I try putting it back in the machine would not close. Please help.
i also need a new journal roll for my casio pcr-t2000 cash register. actually i need 2. one register...
(More)
I ALSO NEED A NEW JOURNAL ROLL FOR MY CASIO PCR-T2000 CASH REGISTER. ACTUALLY I NEED 2. ONE REGISTER CAME WITHOUT ONE.
devido a net - precisaria modificar o tom e/ou pulse. por favor - veja se pode me ajudar onde...
(More)
devido a net - precisaria modificar o tom e/ou pulse. por favor - veja se pode me ajudar onde configurar. maria inez mimchiarioni@gmail.com em portugues.
