When car audio (pioneer mosfit) works as radio or aux every thing are good but when works as cd player(mp3 or audio tracks) only right sid of speakrs work thanks
SOURCE: VSxD209
Hey there denisr, please take look at the display screen on the unit. If you see MONITOR, indicated in the display, then this is your problem . Simply deactivate via the button on the front of your machine. Hope it helps. Good Luck!
SOURCE: JVC KD-G431 IN CAR CD PLAYER "000ZAAA" Error
I had the same problem. It started when I tried to play an MP3 track from a "Creative Zen Vision M" Media Player. The result was the same as you describe = Maddening. It was extremely annoying that the CD player did not work. I thought I had broken the equipment.
Then my wife read the product hand book , and noticed on page 2 http://jvcmobile.co.uk/documents/products/KD-G431%20Instructions.pdf it showed, where using a pen you can reset the equipment back to the original settings. I thought I might as well give a try. It worked = Fixed. Amazing. I was so relieved. Such an easy solution.
Give it a go. I reckon there is a good chance it will fix your problem, and you will also be very relieved. Just use a basic MP3 player in future. GOOD LUCK !!!
SOURCE: Hi, I have a Panasonic
Hi, I have the Panasonic SA-EN9, and if you plug your mp3 player (I have and ipod) into the auxiliary socket you should be able to play it by pressing the AUX button on the remote provided.
Hope It Helps :)
