Question about Bang Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone
Continuous `no dial tone` message on beocom 4
Cannot make calls as i get no dial tone. `no dial tone` message constantly appears
  • Bang Olufsen Master
  • 7,993 Answers
Contact your Phone Carrier.
Posted on Nov 28, 2013
The dial tone is a flat continuous tone, I can not make any calls.
have the line checked, the dial tone is on the line not on the phone . I some time have a flat continuous dial tone and some time have a repeating one
Jun 29, 2015 | Lands Phones
Does not ring
If you recently dialed 4-0 or 4-1, those are Do Not Disturb and Call Forward codes. if this is what happened, then dial the cancel code for both, which is 4-2. This is with internal dial tone, don't grab an outside to do this. You could have someone dial your extension to test if the ringer is faulty. if their call comes in as voice announce, have them add a 1 to their dial sequence and their call should switch to audible ring, and you will know it's not a ringer issue. Adding a 1 can be done continuously if you want to switch back and forth.
Jan 07, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
MESSAGE LIGHT CONTINUES TO BLINK ON ALL HAND SETS (THERE ARE NO PENDING MSGS) WHEN I TRY TO DIAL OUT, (INSTEAD OD A STEADY DIAL TONE) I GET A RAPID BEEPING DIAL TONE) AFTER 7 TIMES, THEN IT BECOMES...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jul 09, 2011 | Uniden DECT 6.0 Cordless Telephone...
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 | Cell Phones
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
When preparing making a call, I get a series of short dial tones.
Have you tried erasing all of your recorded messages? Usually the short dial tone beeps mean you have a pending message.
Jan 05, 2009 | Big Button GE 29369GE1 Speakerphone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Bang  Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone Logo
289 people viewed this question
Top Bang Olufsen Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Bang Olufsen Lands Phone Expert? Answer questions, earn points and help others
