Question about Dishwashers
Forgot to remove knock out from disposal. the dishwasher was run and waater backed up inside. removed the plug and tried to run the dishwasher. you can hear the motor humming like its going into wash but no water is spraying?
    Problem Solver:
  • 6 Answers
I am assuming you cleared all the old water out and the drain is now clear. Dig out your manual and do a "factory reset" if you can't find it in the manual should be able to find it on line. Sort of starting over type of thing.
Posted on Nov 27, 2013
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
  • 51 Answers
SOURCE: dishwasher not working
Nothing by the sound of it. The humming may mean the main pump is stuck. If you are able, remove the pump & turn the impellor by hand (or screwdriver) just to make sure its free moving. Put it back into machine & see what you get. Could also mean that the capacitor on the main pump (if it is a capacitor start motor) has failed.
Posted on Jul 25, 2007
SOURCE: Dishwasher does not cycle
couldn't it also be the pump itself is not working? Hate to diagnose the wrong parts
Posted on Nov 16, 2008
DISHWASHER FILLING UP WIYH WATER WHEN NOT IN USE
Check to see if dishwasher drain is attached to garbage disposer. Running the disposer when the dishwasher drains and it will help keep it clean but if the disposer drain line plugs then the water can drain back into the dishwasher. If it does not connect there then you have a slow kitchen drain and this can be fixed by having a plumber snake it. Often it is plugged with grease that can be cleared with boiling hot water poured down the drain. If this is not the problem then check to see if the dishwasher drain is raised as high as it can go under the sink cabinet. Fasten it up with a strap if needed. This will create a trap to keep the water from flowing back into the dishwasher. Do this regardless of your problem. Lastly If the dishwasher does not drain and it is connected to the disposer then the problem is that the knock out plug was not removed when the disposer was installed. Remove the hose at the disposer and knock it out with a screwdriver. This plug is there so you can install disposer without tying a dishwasher in. Otherwise it would leak there. A slow drain may back up and run into the dishwasher before you see any water appear in the sink. If you raise the dishwasher line to the underside of the counter top you should see water in the sink before it begins to drain into the dishwasher. A slow drain may only show up when you are doing a lot of dishes.
Oct 21, 2014 | Dishwashers
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 | Dishwashers
My Kitchen Aid superba does not drain. It just happened after I replaced my garbage disposal. I folllowed all of the instructions. How do I check for blockages, etc?
easy job, DISCONNECT POWER..... YOU FORGOT TO KNOCK OUT THE DRAIN PLUG ON THE DISPOSAL.... remove the drain hose off of disposal and push a screwdriver into the opening..does it go thru or does it stop...if it stops..take a hammer and knock the end of screwdriver forcing out the plug...remember, to remove plastic plug from inside of disposal....Do not turn power back on until finished
Jan 23, 2011 | Dishwashers
My GE will not drain at all, I do not hear the drain cycle. We did recently replace a disposal, can this cause the diswaher not to drain. If so, how do we check this and fix it?
Sorry to read about your problem, I hope this helps you out.
i will assume you hookek the dishwasher to the garbage disposal... their is a knock out plug you have to remove from the disposal..you will have to remove the disposal, take a screw driver and put it into the place the hose hooks up to, and remove the plug.. hit with hammer. if you put your finger in the hole you will see its blocked
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE Dishwashers
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dec 23, 2010 | Whirlpool Dishwashers
I installed a new food grinder under the sink. I also replaced the dried out rubber hoses that connect the food grinder to the dishwasher. But no matter what program I use, the dishwasher refuses to drain...
Check to make sure you removed the plug inside the garbage disposal inlet where the dishwasher drain hose connects. This is a common mistake installers make when installing a new garbage disposal. Make sure the power the the disposal is secured and remove the drain hose. Place your finger inside the inlet on the side of the disposal. The opening should be clear. If not, you simply need to insert a flat blade scewdriver through the inlet connection and tap out the plug with a hammer. The plug will pop out inside the disposal, so you will need to reach inside and retrieve it before attempting to use it. Once the plug is removed, reinstall the drain line and test operate your dishwasher by starting a cycle. Once the dishwasher fills and begins the wash cycle, press the STOP/CANCEL button to initiate a drain cycle. Your dishwasher should drain with no problems. If you have any questions, please post back and let me know. I hope this helps you.
Nov 19, 2010 | Whirlpool Dishwashers
After I installed my Badger 5 my dishwasher would not drain. Is there a plug in the dishwasher port on the side of the disposal and how do I remove it?
There is often a plug in the ISE as many people use them without have a dishwasher connected to them. Quite often it is just a thin plastic membrane that can be knocked out with a screwdriver. There should also be a note to this effect in your installation instructions for the ISE.
Sep 14, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water standing in bottom of dish washer. Just replaced the garbage disposal.
You forgot to remove the round "Knock Out" Plug in your new garbage disposal. Check your new garbage disposal manual.
Feb 23, 2010 | Jenn-Air Dishwashers
I replaced a disposal and now when I run the washer cycle the used water shoots out the drain that is on top of the sink. It didn't shoot out that drain while the old disposal was working and the dishes...
The new disposer has a plug inside the dishwasher nipple that you must knock out. The dishwasher hose nipple is plugged so water won't leak out if you don't have a dishwasher connected. You must take a flathead screwdrivers and knock out the plug inside the nipple with a hammer or something. Make sure you don't leave the plug inside! The air gap is designed to prevent water from siphoning back into the dishwasher. With the disposal's drain connection blocked, the water exits through the air gap!
Feb 15, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
How doI hook up to dishwasher - How do I remove the cap?
you're already on the right path of doing what needs to be done. you have to use a long flat screw driver (or anything small and long enough to reach the knock-out) and punch/knock out the drain plug of the garberator. once you knock it out, you'll have to remove the piece that comes out of the plug. it's best to do this with the unit out on a bench or something though. (although I never remove the unit from the sink, but I've been doing it a very long time now)
good luck
Sep 27, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwashers Logo
120 people viewed this question
Top Dishwashers Experts
