Question about Marantz New Original RC014SR Remote Control
Cant get marantz rc014sr remote to learn a command from another remote
Marantz sr6006: when I turn it on it is stuck. On the screen i get the screen saver, there is no music in the speakers and i cannot control it from any remote control or from the buttons in the receiver...
If you are using a universal remote, it may be sending too many commands too fast, and locking up the receiver. Try increasing delays between commands in the remote. You may need to wait a second or two after powering up the receiver.
Jan 30, 2015 | Marantz Audio Players & Recorders
Need to program remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Aug 19, 2012 | Marantz New Original RC014SR Remote...
Won't control Sony da4400es receiver
Hi. If your remote is not able to control any of your devices, you can take advantage of its learning capabilities. The Harmony One remote is able to learn commands from your original device remote, so that it can properly mimic the remote.
To learn commands, log in to your software account and click on the "Devices" tab. Next to the icon for your receiver, click "Learn IR." This will take you to a page with all of the receiver's commands, which you can learn one by one by selecting them and clicking "Learn."
Hope this helps.
Jul 10, 2011 | Logitech Harmony 900 Remote Control
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    We own the Logitech Harmony 550 universal remote and recently purchased the Insignia NS-L32Q-10A for some reason we can't get the Logitech to work with the Insignia, any suggestions?
    Does the device not respond at all?
    You can try learning the commands from the original remote to ensure that they are correct.
    1. In the software, click 'Learn IR' next to the icon for the device. 2. Go through the list of commands and learn the ones you think you will need by clicking 'Learn'.
    The important commands of course are the power commands and input commands. Also channel and volume commands.
    Hope that helps :)
    Apr 05, 2010 | Logitech Harmony 550 Remote Control
    I need to know what codes I have to use to synchronise my ProTechnik Amplifier to my logitech harmony 525 remote and I cant find any answers anywhere else. If you can help me please do
    hey there,
    I think you can try learning the commands from the original remote. I couldn't find to correct codes for my TV also and Logitech support suggest that. They said to learn the commands in raw..i guess you can find it in customizing buttons in the software and rather then clicking learn ir scroll to the botton of the page and select custome i think. The software will have steps too that you can follow.
    I hope that I was able to help you..
    Oct 25, 2009 | Logitech Harmony 525 LCD Remote Control
    Logitech Harmony One remote is controlling 2 TiVOs at once.
    Please try learning the some commands from one of the original remotes for thr tivo. If this fixes the problem, i suggest that you learn all commands from that remote.
    Launch the Logitech Harmony Remote software and login to your account
    1. Click on the Devices tab
    2. Click on the Learn IR button for the device you want to learn command(s) to.
    **NOTE: When learning new commands, there are three different options available:
    -You want the Harmony Remote to learn a single command that is already listed in the software
    -You want the Harmony Remote to learn more than one command at a time
    -You want the Harmony Remote to learn a new command, which is not listed in the software
    a. Click on the Learn button next to the command you want to learn - Proceed to Step 5
    a. select one or more commands by clicking on the check box next to the command(s) you want to learn and then
    b. click on the Learn Selected Commands button
    c. Proceed to Step 5
    You want the Harmony Remote to learn a new command, which is not listed in the software:
    a. Scroll down to the button of the page
    b. In the Learn a New Command box click on the text MyNewCommand
    c. enter the name of the command you would like to teach.
    d. Click on the (Learn New Command) button
    e. Proceed to Step 5
    5. Follow the onscreen directions for learning commands, plugging in your Harmony remote when asked and lining up your original remote to the Harmony as illustrated on the screen.
    6. When a command is successfully learned, a check mark will appear next to it. If learning more than one command, the software will then prompt you to learn the next command.
    7. The commands that were learned should now be identified as from "Your original remote" and highlighted in turquoise.
    8. When you have finished teaching the commands, click Done button to save your changes
    9. Click on the Update Remote button to update your remote
    If this does not work, try :
    To teach commands for your Device that did not work properly in normal mode:
    1. Click the Devices button on your home page.
    2. Select the Device you wish to learn commands to.
    3. Select Learn Infrared Commands.
    4. Click Custom. The page will reload.
    5. Select the boxes for commands you would like to teach, and click Learn Selected as Raw.
    NOTE: When teaching each command, press the button on the original remote for as long as required to control the device. The commands will be learned with the exact format that is sent by the original remote.
    If you have any trouble teaching the commands in RAW, complete the following steps:
    1. Verify you are pointing the original remote at bottom end of your remote, and are holding the remotes 2-4 inches apart.
    2. Minimize the amount of light that could interfere with the learning process by covering the distance between the remotes. Block out sunlight, or turn off the lights.
    3. Check that you have installed new batteries in the original remote you are trying to use to learn commands. If the batteries are low, the signal coming from your original remote may be too weak for the remote to detect.
    4. Be sure to hold down the button on the original remote for at least 1-2 seconds, otherwise the signal may be too short for the remote to process.
    5. If you continue to have trouble teaching the commands, start with the remotes 2 inches apart. Then try again with, slightly increasing the distance each time (2.5 inches, 3 inches, etc).
    6. Vary the angle at which the original remote is pointing at the bottom of the remote.
    7. Ensure the device's original remote is sending infrared (IR) commands.
    NOTE: The original remote is sending RF or UHF commands from the original remote if it will control the device from another room, through a wall).
    Oct 04, 2009 | Logitech Harmony One Advanced Universal...
    On the Marantz SR-18 amp how do I switch the DSS setting from Dig 2 to Dig 3? Our sound is coming in on Dig 3 and somehow the setting got changed, probaly an errant command on the remote
    You have to assign the digital inputs on the setup menu from the remote control while you have the On screen display on a monitor or TV screen.
    Feb 10, 2009 | Marantz SR-18EX Receiver
    Deactivating tv remote control codes
    I am not certain these are the instructions for your specific remote. If you are brave, give this a try.
    To Clear all Learned Commands under a mode
    Clearing learned commands is helpful if, for example, you
    replace your CD player with another brand or model. If
    you had learned a feature from your old CD player’s
    original remote on to this remote (such as RANDOM
    PLAY), that feature would no longer work for your new
    CD player. Should you wish to remove or clear one or
    more “learned” commands, follow the steps below:
    indicator turns on. Release the SETUP button.
    2. Press and release the button for the mode you want
    to clear (TV, VCR, etc.). The red indicator blinks off.
    3. Press and release the LEARN button TWICE. The
    4. Press and release the SETUP button. The red
    indicator turns off. All learned Commands under that
    mode are now cleared.
    Master Clear - To Clear all Learned
    Commands under all modes
    2. Press and release the LEARN button TWICE. The
    3. Press and release the SETUP button. The red
    indicator turns off. All Learned commands in the
    remote are now cleared.
    If you would rather error on the side of caution, here is the link to Philips Customer Assistance. It will help you locate the correct model number and the appropriate User Manual.
    http://www.support.philips.com/support/html/index_us_en.html
    I hope this helps, good luck!
    Kym McC
    Oct 05, 2008 | Philips Magnavox Learning Universal Remote
    Marantz New Original RC014SR Remote Control Logo
    90 people viewed this question
    Top Marantz Televison & Video Experts
    Electro Med Services...
    Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
