Question about Electrolux Washing Machines
I have an Electrolux EW880F Front load washer and it starts the cycle and water starts to go into the washer and then it stops. I have cleaned out the filter at the bottom right of the kickboard and found all sorts of hair clips and stuff. It is still doing the same thing. Can you advise what to do now?
  • Trace Mills
    Trace Mills Nov 27, 2013
    Is there a way to reset the Electrolux EW880F?
  • Trace Mills
    No there is no error code or beeping. It just stops and the clothes are wet because it fills a little...Thanks
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
Front load washers of all brands are horrible things. Usually, its the cpu, which is the "brain" that tells each part what to do. Is there an error code or is it beeping?
Posted on Nov 27, 2013
Testimonial: "No there is no error code or beeping. I get the feeling it needs resetting after cleaning out the filter. I could be completely wrong.Do you know how to do this? Thanks"
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: Maytag Neptune MAH8700AWW Front Load Washer doesn't always drain
Need to see a picture of how to take off the front loader
Posted on Jan 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Posted on Sep 18, 2010
dcramer531
  • 1654 Answers
SOURCE: My top-loading Fisher & Paykel
The pump may be clogged as well and needs to come off to clean it out. Get a pan or something to catch any water that will run out of the machine. Then lean the machine back to look under the machine.When you are looking under the machine look to the front right and you should see a black fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely if not then it is binding. The pump should coime of after you unclip it and remove the ground wire and it will twist Counter clock wise and it will come off, get the pan under the pump before removing it.
Some of these models are accesable from the tub. The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor. Make sure the impellor turns freely, if it does not you may have a problem with the pump motor. here is a link to a manual. http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/dryer-wiring-3-wires-to-4-/dryer-timer-notes/fisher-paykel-notes/426348smartdrive-gwl03us-washer-servF%26PGWL03ElecWasher.pdf?attredirects=0
Also check all drainage from the machine to the drain for blockage
Posted on Aug 14, 2011
How to clean Electrolux front loader washing machine
Thank you for your inquiry, Charles!
From my understanding you need to clean your Electrolux front load washer. The best way to clean out your washer is to use a hot water cycle and a cup of bleach. I would also recommend cleaning the front gasket using a water and bleach solution. You can visit a home store to see if they offer any type of washing machine cleaner as well. I hope this information is helpful to you. -Matt
Jun 06, 2015 | Electrolux Washing Machines
My Electrolux ew880f front loader won't start. The end 2 light continually flash. Am I able to reset it. The last cycle washed perfectly.
Try unplugging for about five minutes to allow it to reset itself. Then plug back in. Hope I've helped
May 31, 2014 | Washing Machines
Electrolux Dishwasher EDW7505HPS stopping a cycle
you could always put dishes needing washing in the washer and run cycle. The electric element will heat the water to 140 degrees and it will clean just fine.
Mar 10, 2012 | Electrolux Dishwashers
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Not spinning after first 3 second spin on start.
You need a new PCB. THis happens often on these machines.
Nov 23, 2007 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
170 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
