Question about Performance Teknique ICBM-7.2GPS
Screen frozen What I can do if the screen don't work only works on the gps
How do I unfroze the screen of my Cobra 6000 pro hd gps? Nothing works
Try to leave it on with no battery supply until it runs completely out of charge and switches off. Only then connect it to your PC and see if it communicates with the software on the PC. If it's still frozen you need to restore it to factory settings.
Dec 15, 2014 | Cobra 6000 Pro HD GPS Navigation Trucker...
Uniden trax 430 frozen
I have had a similiar problem with my Trax 430. The screen freezes at the system shut down stage. I have to plug it into the computer via the USB cable. It then recognizes the computer and attempts to do an USB update. Then just unplug it. It should work but not a practical solution when you are driving about.
Jul 10, 2009 | Uniden TRAX-430 GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
NAVIGON GPS
press reset and then power on
Sep 12, 2008 | Panasonic Navigon 5100
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Navman iCN 550 GPS frozen on start up screen and makes a noise like it is stuck
Try hitting your reset button if you haven't already. I had the same problem and this worked for me.
May 15, 2008 | Navman iCN 550 GPS Receiver
Performance Teknique ICBM-7.2GPS Logo
22 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
