Question about Samsung Precedent Smartphone
PHONE stuck on emergency,, how do I unlock it, SCH-S738C
Phone will not let u make any calls , except emergency.no menu ,how do I unlock the phone ??
Sub Zero
  • 55 Answers
SOURCE: Samsung SCH-u540 Cell Phone
It sounds like your charger is faulty, or your phones charger connection is faulty, try borrowing the same charger from a friend, if it does the same thing, your phones connection is faulty Regards
Posted on Jul 30, 2007
SOURCE: my phone is stuck in phone off mode
dont know anyone
Posted on Dec 15, 2008
SOURCE: samsung phone model sch-r210
the master code samsung New phone 587846 100% TEST
Posted on Dec 17, 2008
SOURCE: Missed phone calls
I was having this problem and then realized I had entered my wife's cell number as an emergency number. When I removed it as an emergency number missed calls from her showed up.
Posted on Dec 31, 2008
jamers2004
  • 96 Answers
SOURCE: Brand new Samsung Sch-U340.Noone can hear me and i cant hear them
Try dialing *22899 and press send.
If that doesn't auto update the phone (you will see on the screen if it does) try *22899# and press send.
Try call again.
Posted on Mar 05, 2009
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Need help with my sch-s738c Samsung phone . android come on telling me to reboot
Kenny, May have to rest, links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung Galaxy Centura hard factory reset
Global Download Center
HOW DO HARD RESET MY SAMSUNG SCH S738C Im locked out of my samsung sch...
Mar 01, 2016 | Samsung Cell Phones
How do I disable airplane mode from Samsung model SCH-S738c phone
Press menu>settings>MORE Settings check or uncheck airplane mode
Mar 02, 2015 | Samsung Cell Phones
HOW TO SET UP SAMSUNG GALAXY CENTURA SCH-S738C
If you're starting from a factory reset, or from a new phone. There should be a setup wizard that allows you to input your Google Account, Samsung Account, Twitter etc.
If you're on a second hand phone, transferring users or the like, go into your system settings, there will be a section for Accounts. The menu location changes depending on your version of Android. In 4.2.2 it's a direct tab at the top labelled accounts.
Go into Accounts. Pull all existing accounts. Remove them. Then add your accounts.
After all your accounts are synced. Your Google and Samsung profiles should pull and allow you to customize your software via their respective app stores.
Jul 10, 2014 | Samsung Galaxy Centura SCH-S738C...
Model number SCH-S738C
My Samsung SCH-S738C, through Straight Talk, "freezes up" all the time. The only way to resolve it is to take out the battery but even that may take anywhere from 1-4 or 5 attempts to get it up and running. Seems to be happening more and more. Any solution would be appreciated.
Feb 08, 2014 | Samsung Propel Cell Phone
Samsung Gt-s5233w turns on does every thing except calling or taking calls or SMS or making calls it has a MSG on screen says Emergency calls only ho do I make my phone work I'm with optus
menu, settings and tools, call settings, location....that might work. Id on't have that exact phone so it may be a little different on your phone.
Sep 16, 2012 | Samsung Star GT-S5233 Cell Phone
Sim not valid
you will have to go to whatever provider that your sim belongs to and have them validate the sim card for your new phone
hope this helps
Jul 24, 2009 | Samsung SCH-R400 Cellular Phone
Samsung Precedent Smartphone Logo
37 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
