Question about Rockford Fosgate Car Audio & Video
1 omh load from a p1000 bd1 amp to 12" subs
12" subs
5 Suggested Answers
  • 7 Answers
SOURCE: audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Posted on Dec 21, 2007
sicaudio
  • 96 Answers
SOURCE: problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Posted on Jan 10, 2009
LVT7857
  • 116 Answers
SOURCE: wiring
Usually an 800 watt peak sub would be a 400 watt rms. Hmmmm. Anyway, just bridge the amp (1x 380) nd keep the gain up enough to stay clean. Watch the sub and turn up gain until it starts to distort, then back it down a hair. Do this with the CD players volume up 2/3 to 3/4 volume with the BASS and treble at zero (bass better at minus 4 or so if you are a bass head! Hope thishelps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • 11 Answers
SOURCE: just hooked up mtx 500d mono amp and 12 inch sub
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
Posted on May 17, 2010
How to get 2 omhs
Look on your speakers to see what ohm they're rated at currently. To get 4 ohm speakers to 2 ohm, simply wire the speakers in series. Meaning that you hook #2 sub to #1 sub and then to the amp. So you will have 1 connection to the amp but you'll be operating 2 subs. Hope this helps
Nov 27, 2013 | Rockford Fosgate PUNCH P1000X5D
Can you hook up two 12 inch subs to a 1000 watt amp?
need more info well you need to look at the subwoofer and see how many watts it can take and if it 2 ohm or 4 ohms single or dual voice coils and on your amp is it mono or 2 channel and what is the omhs for it
Mar 11, 2010 | Alpine SWS-1223D Car Speaker
I have two 12 in. subs single voice coil and need to know if could run a 1 omh stablb amp and if yes and how
Yes, you sure could. Each sub is a 4 ohm load. When you put them in a box connect a wire from the + terminal on each speaker, and connect that to the + terminal on the box. Do the same from each - terminal, connecting to the - terminal on the box.
This is called "wiring in parallel" and it will split the load in half, so you present a 2 ohm load to the amp. Since your amp is rated down to 1 ohm, it will work just great.
Feb 07, 2010 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Amp goes into protect when turned up.
that amp is only stable 2 about 4 omhs mono the powersupply shut dowm drawing t much current it supposed 2 2 fix this u need a 4omh load mono change speaker config so u get 4 omh or buy amp stable down 2 1omh can be expensive
Aug 28, 2009 | Sony XM-2002GTR Car Audio Amplifier
How do i hook them up to work for 2ohm's
Hello rcantu76,
If your CVR's are 2ohm (model Nr. 07CVR122), you connect the voice coils in series and then parallel both subs to the amp. If the subs are 4ohm (model Nr. 07CVR122), they cannot be wired to 2ohms. Your choices are 1ohm or 4ohms. According to Rockford-Fosgate's data on the P1000-1bd, it is stable at 1ohm.
To wire the 122's at 2ohms, you would connect the sub voice coils in series (jumper one positive to the other negative on each sub), and then connect the remaining positives and negatives to the amp.
To wire the 124's at 1ohm, you would connect all of the positives and all of the negatives together to the amp.
Hope this helps.
May 11, 2009 | Jl Audio 500/1 Car Audio Amplifier
Good price
Hello smoot_dog,
Well, you did not specify whether you have the 2 ohm or the 4 ohm versions of the L7 and that will impact your choice of amps. But with 8 voice coils and 4 subs to work with, you certainly have lots or potential configurations.
If your subs are the 4-ohm version, I would recommend the Alpine MRP-M1000. Currently it is on sale at www.crutchfield.com for $347.00. With this amp you'd wire the voice coils in parallel (2 ohms), wire each of the 2 pair of subs in series (4 ohms), and the resulting pairs parallel to the amp for a final load of 2 ohms.
If your subs are the 2-ohm version, I would recommend the Rockford-Fosgate Punch P1000-1bd which is stable at 1 ohm. Crutchfield sells it for $349.99. With the Punch and 2-ohm voice coils, you'd series the voice coils (4 ohms), parallel each pair of subs (2 ohms), and then parallel the resulting pairs to the amp for a final load of 1 ohm.
Either of these amps will provide an honest 250 watts RMS to each L7. They'll not only rock your vehicle, they'll rock the pavement.
Apr 14, 2009 | Car Audio & Video
Is my amp powerful enuff for woofer
That amp should work fine for that sub, but you should make sure that the amp has a good power system going to it, and the box for your sub is the right one. Either one of those things could cause problems if not done correctly.
-Dynami
Apr 02, 2009 | Volfenhag ZX-4812 Car Subwoofer
Wiring
Larry T
Winona Lake, IN
Jan 27, 2009 | Pioneer GM-5300T Car Audio Amplifier
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
Need to know
I'm assuming that you have an amp that you are installing these to. Its always tricky installing subs of different impedances. Do you have the model number of the amp that you are hooking them up to.
Most likely if you have a 2 channel amp, you would connect one sub to each channel as most amps can handle a 2ohm load in stereo, but don't bridge the amp with these two subwoofers without specific instruction from someone with experience as you will most likely overlad the amp. If you can be more specific with your set-up I'd be able to assist you more.
Mar 30, 2008 | Alpine Type-R SWR-1042D Car Subwoofer
Car Audio & Video Logo
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
