LG WASHING MACHINE TOPLOADER WF-T7014PP
IT'S MAKING A GRINDING SOUND?
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
I have a LG model WF-T7014PP. It stopped with the first spin in washing program. The breaks is still on, but it seems if there isn't any electricity. Power points is checked- other appliances is working...
2 points to check
ensure that the lid isolator switch is activated when the lid is closed
Check that the out of balance micro switch is operational
Mar 18, 2015 | LG Washing Machines
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
LG top loader now has a very load knocking sound and the cycle stops at the spin stage although the readout goes right to the end so you lift the lid and voila wet clothes
Does it knock all the time? Have you tried it empty? Have a look at the springs or shock absorbers,maybe one is broken or the weight attached to the drum, is it secure and properly located? Check for play in the drum bearing by moving the inner drum side to side against the outer (and also listen to see if anything is trapped).
Apr 19, 2014 | Washing Machines
Lg fuzzy logic model wf-t7014pp. seems like spinner belt is worn, loose, how do i replace it or tighten the belt
plz replace the belt if it is worn ..its better to take preventive maintenance than breakdown maintenance
Aug 18, 2011 | LG Washing Machines
My machines (WF-T7014PP) pulsator circle came loos what do i do?
starting washing after water lever sensor motor cannot function error, spin & wash alarm blinking.
May 30, 2011 | LG WFT1071TP Top Load Washer
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Sep 22, 2008 | LG WFT1071TP Top Load Washer
LG TOPLOADE WSHINGMASHINE WF-T7014PP
call 0800 54 54 54
or visit them in Barbra Road in Isando neer the N12 crossing
Jul 16, 2008 | LG WFT1071TP Top Load Washer
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
