Question about HP Pavilion ze2000 Notebook
PXE Rom Ive replaced my power cord to my HP ZE2000 laptop and since then ive replaced the hard drive, now im getting all kinds of blue screens. Now i can't seem to get past the screen that comes up stating PXE ROM. Any ideas what i can do to get past this screen and boot up? Im very inexperienced in computers but if some one can give me some ideas I'd be grateful
  • 32 Answers
In replaceing the h/d, did u forget a screw that holds something down.?, sometimes metel to metel acts like a heat sink to get rid of  harmful heat. If u started getting "blue screen" of death after h/d replacement. look for anything loose on mother board .Check connections to cpu\fan\heat sink.
Posted on Oct 11, 2007
PXE-E61 : Media test failure, Check cable. PXE-MOF : Exiting PXE ROM
You gotta a bad hard drive and it's not recognized when the computer is powered up. The ZE2000 uses good old 2.5", 9.5mm(height) ATA/IDE drives and the stock drives are of the slower variety (4200rpm rotation speed) - it's probably easy enough that anyone can get a new one (and a faster one of 5400rpm or 7200rpm) and replace it within a minute or two. Best source for these things is by mail: buy 'em on Amazon or eBay and in general, don't pay over 50 cents per gigabyte or you'll look like a tourist.
HP puts out its service manual online, so I'll just pass along the link (this may or may not be for your exact model, but for hard drive replacement, it's all the same):
HDD replacement is page 110, I believe. Removing and installing a hard drive should take no more than 120 seconds.
Of course, you'll have the load Windows after the installation, and that'll take roughly 60-90 minutes.
Sep 14, 2011 | HP Pavilion ze2000 Notebook
Hi, i put together my own computer, ive got the following components: i7 870 processor CPU 8GB RAM 2TB hard drive (two separate 1TB's) NVIDIA GTX 470 DP55KG extreme motherboard coolmaster 850w...
It is telling you that the motherboard can't find the first item on the boot order where it is looking for an operating system, or a bootable disk CDR-DVR. This is usually the DVR Optical Device, or it may be the hard drive. Check your connections on DVR and Hard Drive both at the device and and at the motherboard. Pins in the hard drive and DVR are fine and easy to bend.
Mar 29, 2017 | Computers & Internet
Booting of my hp laptop to so long
U can try disabling the unwanted programs from the startup.
Type msconfig in the run window and u will get the system configuration utility. U can use it to disable the startup programs.
Jun 01, 2010 | HP Pavilion ze2000 Notebook
My notebook stop booting up it is saying.
unplug all the cables connected to the laptop.The moment u torn on the comp keep on tap the key F8 on the keyboard.try the options like last known good configuration,safe mode. i believe it will work after that boot your computer normally. if it doesn't we need look the BIOS settings. for that it is advisable to take your laptop to the service station..
Aug 20, 2009 | HP Pavilion ze2000 Notebook
Sounds like it is trying to boot from network drive. Have you changed the bios boot order. If so, change it back to boot from hard drive first.
Jun 10, 2009 | HP Pavilion ze2000 Notebook
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
System Restore
It seems that your computer is not booting from DVD-ROM drive nor hard disk, but is trying to establish a network setup of the operating system.
You have to go to BIOS settings and correct these preferences by making your hard disk the first boot device. Of course that would be a solution if you have operating system installed on it. If there is no operating system installed on the hard disk, you will need to install it. In this case, your first boo device would DVD-ROM or CD-ROM, whichever available.
Jan 16, 2009 | Toshiba Satellite M35X-S349 Notebook
Acer aspire 5630 wont boot up
it may be that the harddrive had broked, or is not properly mounted. Try removing it and then reatach it. what operating sistem do u use ?!
also try booting with a linux live cd and see if it can accesc the hard drive, if it cant, than thatşs u're problem. If it can, than u have to find out what PXE-E61 is (what component), and then test it (i presume is the hard drive or the optical unit)
May 01, 2008 | Acer Aspire 5100-5033 Notebook
Aspire 3000 will not boot
Hello Halfwit, Your laptop is trying to boot from lan because it can't for some reasons to boot normally from the hard-disk. Try to listen if when you power on the laptop the hard-disk spins or makes any noises. If not there could be a problem with the connector that links it to the mainboard. If you hear a noise or the hard-disk spins then you may have a corrupted OS (windows) or some bad sectors problems. The best way to find out would be to try to boot the laptop by using a windows instalation cd. Boot from the cd-rom and check to see if the windows installer find your hard-disk and can copy files to it. You will need to change the boot order from bios to enable the cd-rom to boot first or enter some boot menu (if provided) and select " boot from cd-rom " or such thing. If you need more help with these please post back or contact me or other experts on the live chat function on this site. Good luck.
Mar 23, 2007 | Acer Aspire 3000 Notebook
HP Pavilion ze2000 Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
