Question about Brother Sewing Machines
I have an (obviously old) Brother PC-8200. All of a sudden, the touch screen has stopped responding when the embroidery unit is installed. It works fine in normal sewing mode, but once I attach the embroidery unit, I can't get it to advance off the opening screen where you have to press the button that says "check." I'm pretty handy, and I know my way around this old machine inside and out (literally), but this one has me stumped. I know if I take it in for servicing, either they'll say they CAN'T service it because it is so old, or it would cost me as much as a new PE770 to fix. I really only want to use this machine for embroidery (not general sewing). Any suggestions?
  • Alison Coons
    Alison Coons Nov 27, 2013
    I have also recently recalibrated the screen, and again, it works perfectly in regular sewing mode. It just freezes up when the embroidery unit is installed,
    New Friend:
    Problem Solver:
  • 8 Answers
I suggest that you stop using it and let it rest. then unplug it multiple times and if that doesn't work, then it's trash.
Posted on Nov 27, 2013
  • 3 Answers
SOURCE: My touch screen
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Posted on Mar 15, 2008
SOURCE: Brother 8200/8500 Upgrade -- opening machine and replacing motherboard
hi, to open the pc-8200 first you need remove the right cover these have 1 screw under a plastic cap.
now you remove the 2 plastic cover in the left side upper and low these are onlu a screw in the back an remove pull to the left side.
Next remove the plastic cover where rest the embroidery these have two screw, you can see easy...
at this time you have only the front & rear cover, this have a hiden screw and lot of presure grapes.
if you need more help sendme a email adrianferra@hotmail.com
Posted on Apr 11, 2008
  • 46 Answers
SOURCE: I have an brother 8200 embroidery machine and when
If you take the face plate off (left side cover) there is usually a small sensor "lever" that is activated when you raise or lower the presser foot. This could be bad or broken. Many models had plastic then they switched to a metal lever. I think this could be it.
Posted on Aug 05, 2009
  • 4088 Answers
SOURCE: Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Posted on Nov 15, 2009
Testimonial: "That was the trick. I knew it had to be something simple but I couldn't figure it out."
  • 98 Answers
SOURCE: How do i do a screen clabration on a brother
try this
While pressing the start/stop, reverse stitch and needle position buttons, turn on the power to display the screen
for the touch panel adjustment mode.
2. While pressing the start/stop button, touch the touch panel at the positions marked by crosses (+) in order from 1 to
5.
(When touching the touch panel, use an object with a rounded tip such as a pencil or matchstick. Never use a
hard or sharp-pointed object.)
If the buzzer sounds once when cross number 5 is touched, the adjustment has been made correctly.
If the buzzer sounds twice when cross number 5 is touched, an error has occurred. In this case, touch the
crosses on the touch panel again in order from 1 to 5.
Never press the thread cutter button during this time. (Doing so may cause a malfunction.)
3. Turn the power off, then on again and check that the screen display and the touch panel positions are aligned
Posted on Jul 01, 2010
Testimonial: "thanks friend"
My touch screen isn't working
Brother 8200 8500 8500d screen ..just found this on youtube not sure if this will help you out
Dec 03, 2016 | Brother Sewing Machines
My Brother PC 8200 was doing an embroidery pattern and suddenly sped up and went crazy! I can't get it to stop sewing motion except to turn all power off. Stop/Start button is red but non-responsive
*Grin* I use to have this machine! It's a very old machine and may not be worth repairing. *tear* It sounds like the on/off switch is broken and un-responsive. The "Sped up and went crazy", part sounds Motherboard related. You never know; take it to a Authorized Brother repair shop motherboard....
Happy New Year!
Kelly
Embroidery Services
San Diego, CA
Jan 01, 2015 | Brother Sewing Machines
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
Brother pc-8500 embroidery machine will not respond to an on-off touch most of the time it works ok when it finally does turn on.
sounds like the computer part of the machine needs to be checked
only a sewing machine repair shop can tell what the problem is
Jan 24, 2012 | Brother Sewing Machines
I have a Brother PC-8200 embroidery sewing machine. Last week I had done some embroidering then changed to straight sewing but couldn't get the tension to adjust. Took it in for repairs, and the...
That's a tough call, parts can be pretty high to fix a machine. Have looked around to price out a new embroidery machine, Janome makes some very nice one in that price range. I'd try ebay there is one which is missing the foot control and hoops for $250.00 just search Brother Pacesetter PC-8200 this may be the ticket you already have the foot control and hoops.
Best of luck
Jan 29, 2011 | Brother Disney PE-400D Computerized Sewing...
How do i do a screen clabration on a brother pc-8200 sewing machine? Thanks for the help
try this
5.
Jun 30, 2010 | Brother PS-1250 Pacesetter
Nov 15, 2009 | Brother PC8500D
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Sewing Machines Logo
249 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
