Question about Dell E153FP 15" LCD Monitor
Our Dell 1905FP monitor lights up very briefly and then turns black with our Dell 510 desktop; but when same monitor is plugged into a laptop it works perfectly. The 510 runs xp. Any solutions or tr
Not sure how this website works, but I may have just posted this question twice. My apologies
  • 2,113 Answers
Everyone seems to post twice
Posted on Nov 27, 2013
4 Suggested Answers
NetSalem
  • 55 Answers
SOURCE: My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Posted on Nov 20, 2009
SOURCE: My Dell 1905FP LCD monitor Power light blink on startup
It's most likely a couple of the eletrolytic capacitors on the power supply board. This type of cap can go bad over time, and that would lead to the symptoms worsening over time like yours has. It's mostly likely a couple of 10V, 100uF caps in my experience. They should be easy to identify: they will be the ones with the top bulging upwards. Replace those and you should be good to go! If there aren't any bulging caps, just replace all the 100uf caps. (there should be no more than 5)
If you attempt this yourself though be carefull: any caps that haven't gone bad can hold a charge even when the monitor is powered off. Depending on the capacitor of the cap, accidentally contacting the leads on a charged cap can be anywhere from painfull to dangerous! A preventative measure is using an insulated handle screwdriver, short both leads of the cap together on the backside of the board to drain the cap.
Posted on Dec 07, 2009
budmrtn
  • 11361 Answers
SOURCE: UltraSharp 1905FP 19" LCD Monitor: I have a Dell 1905FP and it will not turn on. The ...
You may have bad caps (leaking/bulging tops) in the power supply or blown fuse. This is what the board looks like.
http://lcdrepair.us/1704fptt-1905fp-inverter-power.html
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 18, 2010
One of my computers lost power this morning due to blown fuse. When I turned everything back on the monitor screen has power and no screen.. it is all black
If the power light is on, but the screen never appears to light up, either the backlight or the power inverter have failed.
May 05, 2011 | Dell UltraSharp 1905FP 19" LCD Monitor
1905FP stuck in PowerSave mode. I'm using as a secondary monitor to my laptop, but won't activate when I send an application to that monitor. Everything worked properly until a few days ago, but I haven't...
Try to connect the monitor to a working PC.
If there is no problem, then you may try your laptop with a working monitor.
If you having same problem may be you should review the process for outputting display from your laptop.
Mar 15, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Hows it going...well i got this dell 1905fp monitor... i plugged everything in and you see that it on but no picture....also the powere light not on...but u see the monitor on you caN TELL
Power supply will be the first palce to check (for this 4 years old monitor), look for bad caps with bulging top, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 15, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
1905FP Monitor Powers up, briefly shows logo, blacks out.
Look inside for bad caps with bulgng tops, worst case will be shorted out transistors in the backlight inverter circuits or bad lamps. Check to see if you do have he 12vdc for the inveter circuits. See example of failed monitors with bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
This is a classic symptom of filter capacitor failure on the power supply board. The Dell 1905FP and 1907FP both use the same power supply and this type of failure is very common. You can repair the unit by replacing the filter capacitors on the power supply board. Here is a picture of the board with the problem capacitors circled and below is a link to a repair guide for this series monitor.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
I hope this helps,
BuddyMc
Nov 14, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dell E153FP 15" LCD Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
