I painted my ath-ad700s. In order to do that I had to cut all wires. Once I reconnected and retried I could only get the left ear cup to work. Ideas?
    Top Expert:
  • Audio Player... Master
  • 34,255 Answers
It would have been helpful to sketch a diagram of the connections before you cut them. Now you will have to result to trial and error to set things right.
Posted on Nov 27, 2013
Soul by ludacris left ear cup problem
BEst to just try to find a repair shop for that sort of thing. Disecting headphones is a risky venture, and 9/10 it results in a frustrated, headphoneless user.
Jan 30, 2014 | SOUL by Ludacris Bolt Signature Series...
Left Ear cup not working.
Either ship them back to manufacturer if still under waranty or you'll have to re-solder the wiring to that speaker if they have become disconnected or yanked accidentally of which the leftside is usually where the headphone cable first enters in the left side.
Oct 10, 2013 | Audio Technica ATH-ANC27 Headphones
I have an audio technica ath-anc7b noise canceling headphone. There is a crackling sound when I tap lightly on the left hand side of the earphone. There may be something loose. How can I open the cas
I was researching a similar answer and discovered that the left side ear piece actually is actually held together with 3 torx screws that are visible upon removing the ear pad and the padding surrounding the driver. I haven't had a chance to attempt a fix yet but remove those screws and see if you can open the ear piece.
Oct 06, 2012 | Audio Technica ATH-ANC7B Headphones
Need to repair a cut wire going from the left ear cup to the right ear cup
In fact the insulated inner wire (the white tube) is the signal carrying wire.
The outer wires without insulation are connecting ground (GND).
Both wires have to be connected to the speaker in the ear piece in order to (re-) build a circuit.
Jul 12, 2017 | Audio Technica ATH-A900 Professional...
I just recently got a pair of Audio-Technica ATH-ANC27 headphones and I've noticed that when I touch the detachable cable the sound shorts out and plays through one side of the headphones.
There is a wire in the detachable cable that is broken inside so might have to cut and rejoin the broken part.Thats why when you touch the detachable cable you happen to move the wire so sound is only transmitted to one ear phone only.
Thanks and good luck
G.
Aug 04, 2011 | Audio Technica Audio-Technica ATH-ANC27...
How do I open Audio-technica ATH-911's? One of th...
hi.
First of all: This headphones don't have a single srew. So be extremely
carefull as everything is glued !
#1 - Removing the logo plate
This isn't need to reach the wires. Just for cleaning purposes.
Remove de soft ring-pillow from the earing.
Remove the textil thick black ring that is glued by the internal outside gently.
Look for the three black metal small wings that belong to the logo plate and
are inserted to the internal side and are glued and/or bended. Unbend them.
Then pull this wings in order to extract the plate by the outside side the logo plate.
#2: Accessing the speaker and it's wires.
This is a very carefull procedure. A mistake and you'll have scrap instead!
Remove the soft ringed pillow from the earing. In the border that the black
sinthetic leader was inserted, insert a medium screwdriver. Gently swing
the driver up and down in order to separate the plastic disc that supports
the ringed pillow from the outside hat of the earing. Do this in circles for
a couple of times or until you begin to ear the glue lightly cracking. After
this the plstic disk separates from the outside hat and all the electric
wiring and speaker are free to repair.
NOTE: A piece of advice: do NOT use instant glue or cyanide glue to
re-assemble. It would be the last repair!
Pedro Regueiras
May 20, 2010 | Audio Technica ATH-A900 Professional...
Left earphone keeps dying out and comes back. Also the red light on the mic keeps coming on which blocks me from talking online.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with this wireless! head set cutting out on the left side is very common for this model. I fixed mine by removing the soft ear cup then the two screws under this cup then carefully pry that top piece off the next lower piece. It will come but it is stuck with some soft glue.
Next, unsolder the two wires on the back of the speaker taking note of the polarity. These wires are what are broken. Undo the screw in the center. With a small screwdriver carefully pry the pivoting cup off the ear piece. It is snapped onto a small ball joint under the screw.
Now remove the four screws and remove the top of the ear piece.
Remove the two screws from the small printed circuit board and unsolder the two speaker wires. You will need to find some new wire that is flexible and not much bigger in diameter. I used some that was too large and had trouble getting the last cap that holds the soft ear cup back on. I also reamed out the holes in the cap and the cup that the wires go through to give them more movement.
Replace everything and solder the wires to the speaker in the same order as removing.
You will need a good small tipped soldering iron.
Good luck
Calvin
Feb 10, 2010 | Logitech Clearchat PC Wireless Headset
Lost sound in the right ear of my audio technica ath-d40fs
The most common problem with earphones are the wires. Usually near the end. You can carefully open the headset to expose the wire connection, and check for continuity.
Nov 28, 2009 | Audio Technica Audio-Technica ATH-D40fs...
Both cans keep cutting out
Check the 1/4' stereo phone plug for broken wires if you can unscrew the shield. If that is not the problem, you will need to replace the plug and the cable up to the left can. I say left because there is another cable from the top of the left can to the right can carrying the right signal. You said left was mostly cutting out so that connecting cable is likely fine. Slip the foam ear pad off the left can and see if there are screws holding the speaker plate to the cup. Inside of the cup there should be a place where the main cord meets up with the other cord. Make note of the connections and the colors of the wires. You should be able to save the cable grommet by cutting the cable close to it and pulling the wiring out of the insulator and then peeling the insulator tubing out. The rest is parts, soldering and careful, patient work. Remember to solder in a ventilated area.
May 03, 2009 | Sennheiser Audio Players & Recorders
Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Jun 05, 2008 | Bose in-ear headphones - Black with...
 Grubhead
Grubhead
