Question about Dell UltraSharp 1905FP 19" LCD Monitor
Monitor works thru laptop but not on desktop
The monitor turns on with Dell computer (5100), but screen after brief action immediately turns black. We then connected monitor to a laptop and it works perfectly. Does this indicate hardware or software conflict? Any suggestions?
  • 5 Answers
SOURCE: E153FP Monitor screen goes black light is green
The capacitors are probably bad. It is a common problem and easily fixed by taking it apart and replacing the capacitors. Try to find Rubycon Capacitors because they very rarely go bad. Do a search on google for bad caps. I have fixed about 30 monitors this way. Dell is a company well known for bad capacitors. It may not be your problem but replacing the capacitors should cost less than $10 if you do it yourself. www.photphot.com
Posted on May 15, 2007
leecom72
  • 4806 Answers
SOURCE: DELL inspiron 6400 laptop screen turned black
this sounds like a classic case of inverter problems, it could be just inverter coil thats gone which is an inexpensive repair, if it is the inverter then its a bit more.
try the Fn the F key that shows two tv screen icons, it may just have switched to external mode by accident
good luck
Posted on Nov 16, 2008
linktriscuit
  • 89 Answers
SOURCE: My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Posted on Nov 27, 2008
abhishek0404
  • 81 Answers
SOURCE: Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Posted on Jan 18, 2009
SOURCE: Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Posted on Jan 29, 2009
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Monitor not working
It may well be dead. Try testing the monitor on another working PC. Also try a working monitor on the problem PC. Then you will know whether it's the monitor or the PC graphics card that's faulty.
Jan 09, 2009 | Dell Dimension 2400 PC Desktop
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Dell inspirion 5100 fell
Before you can think of fixing it, ask yourself what is there to fix.
open your laptop check for any broken parts on the board if its fine which i highly doubt also check whether any broken piece got into the fun. And for the monitor connect an external monitor and see what happens.
Jun 19, 2008 | Dell Inspiron 5100 Notebook
Black screen on Acer 5100, but will work with external monitor
It sounds like the control board or cable for the LCD may be damaged. If you're still under warranty, you'll need to send it back to Acer to be repaired.
Feb 13, 2008 | Acer Aspire 5100 Notebook
Black (non-usable) screen on 1/3 of entire computer screen
from what your saying, it may be that your monitor may be going bad and may need to be replaced.
I suggest calling dell and try to get your monitor fixed,
or you may buy a seperate monitor, just make sure it has a VGA port so that you may use the monitor.
Nov 12, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell UltraSharp 1905FP 19" LCD Monitor Logo
23 people viewed this question
Alun Cox
