Question about Seagate 750GB FREEAGENT SATA/USB 2.0 750 GB Hard Drive
Seagate FreeAgent 750GB ext HD - not recognized, bleeps fan noise
Yesterday I accidentaly pulled a wire, and my external Seagate FreeAgent 750 GB HD (USB 2.0) tilted down.
The drive stands in a vertical position, so any slight touch is enough to make it tilt. But anyway, it wasn't a big impact (it was already on the carpet floor).
As soon as this happened, the drive disappeared from my laptop (in which it was connected) and started to make a harsh sound, that sounded like a cooler fan being dragged the wrong way. There was also a very low and costant beep.
I have read the relative topic at the Seagate forums, and it seems a lot of people is facing this issue, and no one had the drive for over 6 months.
The company offers no solution at all, but the standard warranty replacement and/or data recovery service (which costs around 300-1.500 $).
I believe the problem should be in the case and if I can manage to fix that, I'm confident the actual HD is still safe. But how can I repair the case without having to replace the whole product thru the warranty?
  • fabiobi May 16, 2009
    Hi Chris,
    Thx for the answer!
    Indeed, I already gave up on the warranty, because I don't want to have another Seagate product. I can't rely my data on this ****, I'm afraid. From now it's Western Digital all the way.
    Yes, I will crack it open and try to connect the sata drive into a desktop... if that works, cool, I'll even use it as an internal drive on the desktop I'm assembling. If it doesn't, then I'd like to know more about that Armor-IT. Do you have more info on them?
    Cheers!
    FS
  • 696 Answers
You generally can't repair the case unless you have another one of the same model for spare parts. Also if you open the case you will void any warranty the drive and case had.
If you are ok with those two points, you can simply buy an empty SATA drive enclosure and pop the free agent apart, place the HDD into the new enclosure and try it on your computer. If this works you're done. However if it doesn't and you require the files from the drive you will be stuck paying for data recovery. There are several more economical options, the one I like best is Armor-IT. Small company in Canada, they do charge a diag fee which a lot of companies don't do but their prices are pretty reasonable for most drives.
Hope this helps,
Chris
Posted on May 10, 2009
  • Chris
    Chris May 16, 2009
    Hello again,
    If you need to get ahold of Armor-IT they are listed in the FixYa directory, I have the number here, 306-222-1683. If it doesn't read on the motherboard just givem a call and have them assess the drive and they'll let you know what's wrong and wether you're looking a the Cheap range of recovery $100-$400 or if it's an ugly one $1000+.
    Good luck either way,
    Chris
Seagate Freeagent 500gb Ext. HD not working.
it´s my first time on this topic, but I´d recommend reinstalling it´s drivers, it sounds like it´s stuck there. Or just to be sure it is working ok, the both connections, esata and usb. If any of them work it´s ok. If not, come back, we´ll figure something out for you.
Oct 19, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 250GB FreeAgent USB 2.0 Ext Hard Drive with laptop
Whether your computer is a laptop or desktop does not inherently decide if the drive will work or not. If it can't see the connection, there must be another problem with the drive. I would suggest reporting what you have done to try and make it work and anything you notice out of the ordinary (how lights on the drive are acting, noises the drive is making, alerts you see when you plug it into your laptop, etc). That will allow us to better help you find a solution to the problem.
Feb 19, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
An error was detected on device \Device\Harddisk2
run dskchk /p /r
What's the pagesize file size?
Check proper seating of cabling as well.
More about chkdsk at:
https://technet.microsoft.com/en-us/library/bb491051.aspx
Aug 02, 2017 | Seagate 750GB FREEAGENT SATA/USB 2.0 750...
Segate FreeAgent 750GB external hard drive
my iqube extenal hard drive is not working was dropd down, I have tryed plag and play and it shows the light and fun inside working and when you staart uyou can ear like its start but stops after few seconds
Oct 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro 750GB
try checking ur USB ports.May be the drive is not supported by ur usb .Try connectin to another system with same OS
Aug 28, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 750GB FREEAGENT SATA/USB 2.0 750 GB Hard Drive Logo
365 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
