Question about Vehicle Parts & Accessories
Gray wire from autopage rf-320 car alarm does not send negative trigger
The gray wire (from 8-pins socket)does not send negative trigger signal to pop the trunk after pressing the transmitter button for 2 second, this wire should provide a 1 second pulse ground to the relay then popping up the trunk as per wiring instruction, any one can help for trouble shooting.
  • Tan Tran
    Tan Tran Nov 28, 2013
    Any button on the transmitter sending the signal to the alarm fine accept the button for trunk release does not work. This indicate that not the battery is weak, however I have replaced a brain new 3v battery but the issue still persists
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
Maybe the transmitter is failing to send the signal. Try changing the battery in the transmitter
Posted on Nov 27, 2013
4 Suggested Answers
  • 5 Answers
SOURCE: I need installation guide for autopage rs-855 car alarm
I've uploaded the installation manual and wiring diagram to Yousendit.com. Here's the link:
https://www.yousendit.com/download/dVlvdFdVdVVrUmxMWEE9PQ
or
http://tinyurl.com/dhs964
Posted on Apr 18, 2009
  • 20 Answers
SOURCE: autopage car alarm install wiring diagram for the
here is a link for the installation manual. hope this helps, dave.
http://www.autopageusa.com/resources/RF420%20INSTALL%20manual.pdf
Posted on Dec 03, 2010
  • 10865 Answers
SOURCE: 1997 Chevy Silverado Car Alarm w/remote Start
Hello m1..... Here is the link to this alarm manufacturer including manuals, etc. If this site does not answer all of your questions, click on their contact icon and speak directly with their technicians. http://www.xlsperformance.com/cars_alarm_starter.htm
Joe
Thanks for choosing Fixya!
Posted on Dec 24, 2010
My youkon alarm goes off every time i unlock the door with the autopage key fob.
Aftermarket alarms have to be configured to bypass the factory alarm system when using it.
I don't mean you have to permanently delete your factory alarm. What I am saying is, when you use your autopage key fob to unlock your doors, it must also send a signal to the disarm wire of your factory system simultaneously. If not, your alarm will go off just like you are experiencing.
May 16, 2017 | GMC Yukon Cars & Trucks
Don't know what the picture on the dashboard is for? Looks like a radiator, but not sure. Misplaced car manual
the alarm automatically arms 30 seconds after you lock the doors
i looked around online and found info for you
The FACTORY ALARM DISARM WIRE IS
lt. green/orange '-'conn. 2, pin 9 @ the BCM.
The factory alarm disarm wire is
negative trigger thru a 473 ohm resistor.
MUST use relay. The BCM
(Body Control Module) is attached to
the left of the fusebox.
Connector 1 is a gray 26 pin plug,
and connector 2 is a gray 22 pin plug.
Once Located, splice into this wire with
a simular guage wire, add the specified resistor
and put it to a solid chassis ground.
This terminates the alarm functions entirely.
However, at this point, this car would be exceedingly
easy to steel, so I suggest you get an aftermarket
alarm system to protect it from here on in.
Take this info to your local
stereo/car alarm guy and have them
do this for you.
Sep 16, 2011 | 2005 Jeep Liberty
2006 jeep liberty. In the middle of the night the jeep would make a honking noise with short honks. We never had the alarm set. What would cause this and how would you turn the alarm system off.
do this for you.
Sep 16, 2011 | 2006 Jeep Liberty
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Why does the alarm in my car go off when I try to start it with the remote car starter?
If this is the vehicle's factory alarm that is being triggered then your factory alarm must be disarmed prior to the remote starter sequence. The Autopage unit has a factory disarm wire available for this purpose. When the alarm triggers again try turning the key in the driver's door to see if there is a factory disarm wire available in the vehicle or if the factory alarm is RF disarm only. If it is the after market alarm that is being triggered then you made need to decrease the sensitivity.
Nov 23, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Where is the door pin trigger wire of Mitsubishi Galant VRG 1996
the door trigger wire is inside the chassis. it goes to the fuse box underneath the dash, where you can tap your alarm. it is usually the fuse for the dome/door light.
Sep 20, 2009 | 2002 Mitsubishi Galant
HORN DIAGRAM FOR A DODGE RAM 1500 (CONNECTIONS)
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Blue (16 Gauge)
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Yellow/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue (10 Gauge)
Accessory Positive Wire Location: Ignition Switch Harness
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Aug 22, 2009 | 1998 Dodge Ram 3500 2WD
Vehicle Parts & Accessories Logo
61 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
