Question about Samsung BP59-00016A Remote Control
Remote Control Malfunction - Non-responsive
I have a 55" Samsung Tantus rear projection TV. There is an LED bar beside the power button with four sections: TV (red), VCR (yellow), Cable (green), DVD (orange).
Last night, the red TV light was flickering and the remote was unresponsive. I changed out the batteries which had left some corrosion on the connections. I have cleaned the connections by air blowing and scraping out all the white crystals.
But now, my remote is unresponsive. I press buttons and it causes the lights to shift between the four modes. If the select button is held, the light stops flashing, is illuminated for a while, and then goes dark. But when I release the button. It goes back to flashing again.
On the TV screen, I can see the display shifting from TV to VCR to Cable to DVD but none of the buttons like "ASPECT" or "VOLUME" will function. Please help!!!
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
  • 172 Answers
SOURCE: Samsung TV Remote
Replace it with a Universal Remote with Learning, This way, if the new Universal codes in its Manual don't work for your Samsung, (they most likely will if the new remote is not used older one bought off eBay) then you can Teach it to Learn codes off the working keys on you Samsung.
Sony Learning Remotes are a very good choice, sold at Walmart or eBay. The advantage to a good Universal, is you can also program in all your other audio/video remotes into one remote.
Posted on Aug 24, 2009
bbl242003
  • 1637 Answers
SOURCE: The remote control for my
Remove the batteries then reinsert them. If the problem persists, please change the batteries.
Posted on Jan 08, 2011
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
Model WS55819, shut off and won't turn back on. The first few times I tried to turn it on, the indicator light came on and went off after a few seconds. Now there is nothing. I removed the panel from the...
Most common problem in WS-55819 is failure of convergence output chips and blown pico fuses in power supply section.
You need to read out error code in tv, procedure is as follows:
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must used, NOT those on the Remote Control.
Example: If the Error Code is "24", the LED will flash two times, pause, and then flash four
times.
Error codes detail:
This way you can determine what section got problem in tv and causing problem.
Let me know if you need further info.
Thanks.
Dec 13, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Hi I have a problem with my 55 in samsung tantus #hcm553w there is a halo around the images what can I do to fix this?
Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to replaced CRT coolant in the tube.
Jun 26, 2010 | Samsung HCM5525W 55" Rear Projection...
Samsung tantus blinking red light
you need to general service the whole unit. this will include re-soldering and changing some defective components from the board, which has been damaged through using from past years. my advice is to have a quotation from service tech and then think about repairing it..if it is better to buy a new one..
Nov 16, 2009 | Samsung PCH521R 52" Rear Projection...
Volume increases to 30 can't turn down
I don't have a solution but if you take off the speaker grille on the front of the set and see two ribbonish cables, unplug the smaller one. The volume will not increase anymore but you cannot use the controls on the front of the tv and the power light will not show green anymore. You can however use the remote to do everything on the set that you would normally do. Hope this helps until I find a real solution.
Sep 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Hitachi 55vf820 problem
Will not turn on. TV is pluged in its almost like a power surge. The power bar is lit so for some reason the tv is not getting power.
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Tv comes on and flick off in one minute
need to know the make and model number of the TV in order to help you.
Mar 13, 2008 | Televison & Video
Tv wouldn't turn on
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the TV.
Jan 04, 2008 | Samsung HCN5527W 55" Rear Projection...
Samsung BP59-00016A Remote Control Logo
184 people viewed this question
Jerry Greenberg
Jerry Greenberg
