Question about Philips Audio Players & Recorders
The clock display no longer works, and the brightness level is at the max
3 Suggested Answers
SOURCE: Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Posted on May 14, 2008
jgroves705
  • 536 Answers
SOURCE: Display is too Dark to work with but brightness lever up to max.
Apparently the backlight for your display is failing. You'll most likely have to have the top half of the macbook replaced per Apple usual service standards.
Posted on Feb 26, 2012
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
Feb 15, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
There is no brightness at all in the display - what would the problem be?
Brightness in display is usually an adjustable feature in most devices and often times due to malfunction this function adjusts itself to the lowest level or someone mistakenly operates it to that level. All you have to do is locate the brightness button and increase the brightness.
If on the other hand this does not work then the LED light inside the unit is either burnt or the wires connecting up to it are burnt. In this situation you will need to refer it to an expert or just replace the unit as cost of fixing might be worth a new one.
Hope this solution has been helpful?
Jan 01, 2011 | Sony ICFCD3iP CD Radio Clock iPod iPhone...
Screen is dim and I cannot fix it. I used a
It has a 12 volt lamp in it that illuminates the display screen. It is not a user serviceable part. You will need soldering skills and tools to replace it.
Apr 28, 2010 | Philips AJL308 USB/SD radio alarm clock
How to set the clock on a 2001 Nissan Frontier
Clock set:
To adjust the clock, press the tune knob for longer than 1.5 seconds. A beep signals entry into the clock adjustment mode and
CL appears in the display. The hours will be blinking. Rotate the tune knob to adjust the hours to the desired level.
Press the tune knob a second time and the minutes will start to blink. Rotate the tune knob to adjust the minutes to the
desired level. After 10 seconds, the radio or CD display will reappear. Once the clock is set to the desired level, press the knob repeatedly until the radio or CD display reappears.
All done!
Jun 24, 2009 | 2001 Nissan Frontier Crew Cab
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Clock
Here you can download user manual in pdf format
From page 107 on Manual:
"Clock operation:
The clock is on in the display regardless of
what mode, media, or function the radio is in
as long as the ignition is in ACC or ON.
Clock set
To adjust the clock, press the knob
blinking. Rotate the knob to adjust
Press the knob a second time and
desired level.
until the radio or CD display reappears."
Jun 04, 2008 | 2001 Nissan Altima
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
