Question about Troy Bilt Tb70ss Gas Trimmer
I have a Troy Bilt weed eater and am having a problem. It starts with the choke on, but it will not run with the choke off.
  • 2 more comments
  • todinet May 08, 2009
    It will run for a few minutes with the choke on halfway. If I keep reving it, then it will usually continue to run, it just won't reach maximum rpm
    I cleaned the carburetor and the air filter as well as the spark arrester. It will now run on half choke at full throttle, but if I take it completely off choke, then it only runs if I give gas very slowly.
    I also changed the spark plug, cleaned the air filter and sprayed the carburetor with cleaner when it took it apart as well as used my air nozzle in each passage. It now will run pretty well on half choke(good enough to weed eat) and idles and runs at slow speed with the choke all the way off. If I take my time giving it gas, it will gradually pick up rpm with no choke, but the power is not what it should be. At least I can use it now.
  • Samuel Charles Spriggs May 11, 2010
    What happens if you just leave the choke on halfway?
    President:
  • Troy Master
  • 1,545 Answers
Ths problem is possibly indicating the need for a new fuel pump diaghram in the Zama carburetor. A carb rebuild kit installed correctly should alleviate this problem and greatly improve throttle response on the unit. The ethanol in the fuel nowadays plays havoc on carb parts and they become less flexible and more brittle, thus affecting performance and leading to problems with throttle response and carburetor functions such as this.
Posted on Nov 18, 2009
    President:
  • 1,489 Answers
I'd clean the carburetor. Try injector cleaner additive for the fuel tank. Mix in same proportion as directions on bottle. Maybe a little higher ratio.
If this doesn't clean it out after a tank full, take it apart and clean it.
Posted on May 08, 2009
  • Samuel Charles Spriggs May 08, 2009
    Oh, by the way, have you cleaned the air filter lately?
    I would still try the injector cleaner.
    If that doesn't work we'll go to the ignition system.
    By the way, have you installed a new spark plug?
2 Suggested Answers
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Weed eater runs slower
Your air filter may be plugged, your pug may be fouled, or your carb may be gummed up.
Sep 10, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Jul 30, 2009 | Garden
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Weedeater starsts and ildes won't run or accerate
It sems to me like your engine chokes itself on a too rich fuel mix, a clogged air filter may cause this condition. Of course there is always the possibility of a needed carburetor adjustment but I would definitely check the air filter first if this machine used to work fine.
May 30, 2009 | Troy Bilt Tb70ss Gas Trimmer
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Blade on my weed eater troy build
I would suggest that you obtain a blade that fits. Reducing the mount will be dangurace
Jan 26, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
2,889 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
