Question about Northstar Pressure Washer 3000 PSI
Had the Northstar 3000 psi Pressure Washer for 2 months and it started leaking oil from the pump during use. Took it to Northern and they are replacing the pump under warranty but said it was likely because I was using quick connects on my garden hose coupling and that was restricting the water flow making the pump overheat. They said never to use quick connects on the garden hose unless the opening is at least 5/8". Does anyone make such a quick connect? I hate having to screw the garden hose on every time, and also having to remove my quick connects at the water spigot end. Thanks.
    President:
  • Northstar Master
  • 1,383 Answers
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
Posted on May 10, 2009
My northstar pressure washer has no pressure
PDF]Owner's Manual - Northern Tool + Equipment
https://www.northerntool.com/.../1577544.p...
Northern Tool + EquipmentCall NorthStar Product Support 1-800-270-0810 .... -During transportation take precautions to make sure pressure washer will not tip ..... A- Low oil shutdown.
Sep 21, 2015 | Northstar Garden
Can i use karcha hose on a northern stsr pressure washer
Yes. Both brands use M22 (22MM) hose fittings. You will need to check that the Karcher hose is rated to a high enough pressure for your washer, especially if it is a thermoplastic hose as they tend to be rated for 2500 PSI.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 01, 2011 | Northstar Pressure Washer 3000 PSI
Does the machine need an oil change, if so how often and can i do it myself?
i would change the oil every 100 hours or six months in the engine.
and would change the oil in the pump every 12 months.
to change the engine oil,look for a 12mm or 13mm bolt at the base of the motor.
it should be at the front of the engine.undo bolt & drain oil into a container.
tighten bolt up & fill engine with new oil.
Dec 09, 2010 | Northstar Pressure Washer 3000 PSI
We have a leak on the pump around the manafold and the gearbox. Has anyone had this problem that you know of? Could it be that the packing has gone out? The washer is 2 to 3 years old and runs great just...
Usually when water is leaking from in between the manifold and the oil side of the pump, the high and low pressure seals (a.k.a. packings) are worn out.
Dec 17, 2009 | Northstar Pressure Washer 3000 PSI
I have a northstar pressure washer with a comet pump AXD 3020G that will not build up pressure, can you give me some ideas on what may be wrong ,I have checked the screen on the inlet ,it is clean
Normally, it is one of three things.
1.) The high pressure seals are bad
2.) There is debris in the check valves
3.) the unloader is stuck in by-pass.
Nov 16, 2009 | Northstar Pressure Washer 3000 PSI
My Northstar Pressure Washer Pump does not boost water pressure
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
May 11, 2009 | Northstar Pressure Washer 3000 PSI
Pump oil leak where pump connects to engine
With that few hours, you need to return it as the seal shouldn't leak. Probably was improper pump assembly, so you should take it back, because it will only get worse and fail. Hope this helps you, Rick
May 04, 2009 | Northstar Pressure Washer 3000 PSI
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
Northstar Pressure Washer 3000 PSI Logo
373 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
