I have a Mitsubishi lt-46515 with no remote! When I power the tv on it goes to a blue screen but I can't do anything. How do I fix it? Can I use a universal remote?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.For more information http://electrohelponline.blogspot.com/
Posted on Nov 27, 2013
snakehead
  • 1074 Answers
SOURCE: Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Posted on Jun 23, 2007
  • 3 Answers
SOURCE: olevia lt 30 hv
You both need to IMMEDIATELY download your warranty from the Olevia website. Read it completely. If you are still under warranty, then contact them IMMEDIATELY in writing pursuant to the warranty and demand that they fix the TV for free pursuant to the warranty. Do not accept "No" for an answer. Document every communication and contact you make, including date, time, who you spoke with (first and last name and/or employee number), and the content of the communication.
Do not delay on contacting them, because the warranty is controlled by the date you purchased the TV. If it passes, then you are totally screwed. Olevia will ignore you.
ALTERNATE SOLUTION:
Do not buy any Olevia or Syntax products in the future. Tell everyone you know to not buy their products either.
Posted on Dec 27, 2007
  • 2318 Answers
SOURCE: White Screen of Death. TV locks up
You will need to replace the power supply or get fix because there aren't too many service parts available anymore.
Posted on Jun 07, 2008
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
LCD TV diplays blue screen on all inputs
Nothing on all inputs would suggest the Main AV board not processing signals, if all other functions such as volume, menu access, on and off operate normally the power supply board is probably functioning OK. Have a look at shop jimmy for an idea on price and availability for Mitsubishi LT-46144 Boards and spare parts:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 11, 2015 | Mitsubishi LT-46144 46 in. LCD HDTV
LT-46151 mitsubishi tv, Green light flashes, no picture, back light is on, screen is blue.
If you have any later digital camera or phone with a compatible connector and cable, try connecting this first.
The set may be looking at the wrong input for signal.
Using your remote, check the setup menu to ensure that your source (cable, receiver, etc.) hasn't been accidentally changed.
Often, a blue screen means 'no signal.'
Jun 04, 2015 | Mitsubishi Televison & Video
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
I have a Mitsubishi lt-46515 with no remote! Once I turn it on it goes to a blue screen and I can't do anything. How do I fix it? Can I buy a universal remote?
You can try to find a universal remote that will control your TV or you can search online for suppliers of exact replacement remotes.
Nov 27, 2013 | Televison & Video
LT-46133 FLICKERING BLUE LIGHT
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
When I turn the TV on it goes to the blue screen but nothing works then the TV powers off on its own.
Blue screen usually indicates no input. Check the input selection. Check the cables from the source. If everything is correct, try this: unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
Apr 18, 2011 | Mitsubishi LT-52153 LCD TV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Mitsubishi VS 50805/60805 blue/yellow shadows on screen
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple do the above
Aug 17, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
