Question about Apex Digital PF2025 20" TV
Black and white
Ok so i have an Apex pf-2050 20" color tv. The blue screen is blue the menu words come up yellow and red, but all the programs i get with my antani and the video from my dvd player all show up in black and white. i never had a remote for it and the menu button options don't give me an option to restore color... anyone have any ideas on why it shows everything in black and white, and how to fix it?
  • 1 more comment
  • Ghetto_cowbo May 08, 2009
    Then why do my DVDS play in black and white as well??
  • Ghetto_cowbo May 09, 2009
    no because if you READ my first post i stated "programs i get with my antani and the video from my dvd player all show up in black and white"
  • fougzki May 11, 2010
    Why don't you get a remote control for you to get full control of the menu. Before we go for troubleshooting.
    President:
  • 1,489 Answers
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
Posted on May 08, 2009
  • Samuel Charles Spriggs May 08, 2009
    That's called withholding evidence. Congrats!
Dvd is playing movies in black and white
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
Feb 26, 2012 | Apex Digital ADV3800 DVD Player/VCR
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
I have hooked up all cables correctly however when i attampt to record of my xbox i get black and white record screen ive tried 3 diffrent record program im using the HD componet cable (blue green and...
Greets - You are mixing cables up. You need to connect the Dazzle yellow, red, white cables to the yellow, red white cables on the TV. You can't plug standard video/audio cables into the component (red, blue, green) connectors on the TV.
take a look at this diagram, just pretend the devices on the left are all connectors on your TV.
http://www.pinnaclesys.com/presskits/Dazzle/DazzleDVD_Recorder_ReviewersGuide_May06.pdf
Good Luck, Mikeywaf
Mar 03, 2011 | Pinnacle Dazzle DVD Recorder
My apex at2402has a blue screen
your' TV is in VIDEO mode... connect your cable or sat. or DVD player or cable box etc. to TV using the VIDEO jacks>>>>red , white , and Yellow wires....picture should be on TV now.
other ways to get a picture also....changing TV from VIDEO mode TO TUNER mode...etc
May 19, 2010 | Apex Digital AT2402 24" TV
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
Color in black and white
Possible solutions....
1) These Apex players can handle multiple sytems (NTSC/PAL)
Is it possible it is switched in the wrong mode?
Follow the jumpy picture and enter the menu to see if it is switched in the PAL mode (You may have to follow the user manual and try to look at the screen carefully while following to menu flow)..
Some APEX units have a button on the remote to switch the systems.
2) I have also seen some TV's that will not handle the progressive scan mode...
Try switching in the menus.
Mar 01, 2009 | Apex Digital AD-2500 DVD Player
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
I just got an xbox 360 for christmas and I play it on my Apex PF 2725 tv. I have it connected to the first Video component with the red white and yellow cords (its set to TV and not HDTV) On all of my...
orite if you have a HDTV plug in all leads apart from yellow 1, but if its normal tv just insert the white, red, yellow. : ), i aint an expert yet
Jan 15, 2009 | Apex Digital PF2725 27" TV
Apex Digital PF2025 20" TV Logo
260 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
