I have a Mitsubishi lt-46515 with no remote! Once I turn it on it goes to a blue screen and I can't do anything. How do I fix it? Can I buy a universal remote?
    Top Expert:
  • Televison & ... Master
  • 43,043 Answers
You can try to find a universal remote that will control your TV or you can search online for suppliers of exact replacement remotes.
Posted on Nov 27, 2013
4 Suggested Answers
SOURCE: I get a flash of blue screen when I power on the set.
I have the same problem.
"I get a flash of blue screen when I turn on the LT 30HV. Then the screen goes blank."
Posted on Aug 03, 2010
budmrtn
  • 11361 Answers
SOURCE: When the JVC LT-26X525 TV is turned on the picture
Either the 24vdc power supply problem or the backlight inverter board problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 07, 2010
  • 26 Answers
SOURCE: I have a mitsubishi tv
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Posted on Nov 20, 2010
LT-46151 mitsubishi tv, Green light flashes, no picture, back light is on, screen is blue.
If you have any later digital camera or phone with a compatible connector and cable, try connecting this first.
The set may be looking at the wrong input for signal.
Using your remote, check the setup menu to ensure that your source (cable, receiver, etc.) hasn't been accidentally changed.
Often, a blue screen means 'no signal.'
Jun 04, 2015 | Mitsubishi Televison & Video
I have a Mitsubishi lt-46515 with no remote! When I power the tv on it goes to a blue screen but I can't do anything. How do I fix it? Can I use a universal remote?
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.For more information http://electrohelponline.blogspot.com/
Nov 27, 2013 | Televison & Video
I have a Mitsubishi HS-U448 VCR. It plays my VHS tapes fine, but I can't get a blue screen when I turn it on. When I press 'play', the movie looks great. Once I hit 'stop', it'
It sounds like it is set to a TV station and since all the analogue stations have now gone you will only get static. Without a remote you wan't be able to switch it. I suggest you either shop around for a replacement (try Curry's partmaster) or use a universal one.
Jan 16, 2013 | Mitsubishi HS-U448 VCR
LT-46133 FLICKERING BLUE LIGHT
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
When I turn the TV on it goes to the blue screen but nothing works then the TV powers off on its own.
Blue screen usually indicates no input. Check the input selection. Check the cables from the source. If everything is correct, try this: unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
Apr 18, 2011 | Mitsubishi LT-52153 LCD TV
Jan 10, 2010 | Syntax LT30HV 30 in. HD-Ready LCD...
Mitsubishi VS 50805/60805 blue/yellow shadows on screen
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple do the above
Aug 17, 2008 | Mitsubishi WS-55807 TV
Mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Apr 07, 2007 | Mitsubishi VS-1250 TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
