Question about Intex "" Metal Frame Pool Set (56998e) 56998e
How do i keep my water clean at all times - Intex "" Metal Frame Pool Set (56998e) 56998e
  • 2,113 Answers
You can put a copper solution in it, or have a salt water pool You still have to clean it. Perhaps put it on Venus
Posted on Nov 27, 2013
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
Apr 15, 2013 | Washing Machines
What is the best product to use to keep these floors clean?
a very mild solution of white vinegar and cold water, with a thick sponge mop and large pail for the water....pass 3 times as wash...and 2 times as clean rinse mop water only....vinegar alos sanitizes and the citric acid cleans naturaly....
Jan 24, 2010 | Venture Shock Athletic Ultra Flex 16pc....
Keeps flashing CLN after cleaning
i had this problem
if u have hard water and do a fresh clean but it dosnt clean it well then it will flash clean time time again
best soultion to clean if u havnt tried it is
Pure Vinegar white..
run through 2 times then clean with water 2 times then ur problem surely will be fixed .. if not hit me up
at
peterjw@bell.net
and ill have more information for you..
best luck
Oct 26, 2009 | Hamilton Beach BrewStation 47224 Coffee...
How do I clean my hunter humidifier 33201? the filter blocks have white calcium? built up. I have sick kids and want it to be clean and running properly.
Soak the filters in a solution of 8 oz of white vinegar per gallon of water for about 20 minutes once per week and rinse well.
Better yet, do this once every 2 weeks, and on the off weeks soak the filters in a beach and water solution (rinse well) to keep the mold and bacteria growth from becoming a problem. I also add about a teaspoon of vinegar or a teaspoon of bleach (one or the other, not both at the same time) to the water when I fill the tank.
That helps keep the calcium scale from forming and it keeps the unit itself MUCH cleaner.
Oct 13, 2009 | Hunter 33201 Humidifier
My GE profile gas range keeps clicking all the time, this happens right after we have cleaned the gas range. And usually it goes away after a few hours. But this time around it refuses to go and it is very...
You are getting water into the range when cleaning causing the igniter switch to short out. The reason why it goes away after a few hours is because the water finally dries up. When cleaning the range refrain from using so much water. You will need to leave the range unplugged until the water dries up again.
Sep 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
May 05, 2009 | Dishwashers
Battery Maintenance
Follow these guidelines every three to six months to extend the life of your low-maintenance Interstate battery: 1) Maintain Water Level. If your battery has removable vent caps, you should regularly check the water level and add water when it is low. 2) Keep Terminals Clean. Visually inspect the terminals and cables at least once a year, especially in hot temperatures, for signs of corrosion. If dirty or corroded, clean the connections with a scraper and wire brush. This will ensure a good connection and proper starting. 3) Keep Case Clean. Keep the top of the battery clean of heavy dirt and oil with a cloth dampened by ammonia or a 50/50 solution of baking soda and water. Then rinse with clear water and allow to thoroughly dry. 4) Keep Battery Charged. If your vehicle is not driven weekly, it may be necessary to charge your battery before use. Lack of use is hard on a battery, especially an automotive battery which is designed to be charged regularly by an alternator. Any unused battery, regardless of its chemistry, will self-discharge over time and, if allowed to remain discharged, will undergo severe positive grid corrosion and battery failure. The rate of discharge depends on the type of battery and the storage temperature. So, it's important to keep your battery charged. If you prefer that your mechanic take care of your battery, be sure to ask him to maintain the water level and to keep the connections and case clean of corrosion and dirt.
Nov 20, 2008 | 2003 Harley Davidson FLHTC Electra Glide...
Battery Maintenance
Nov 20, 2008 | 2008 Harley Davidson FLHRC 105th...
KEEP HAVING TO KEEP CLEANING BLACK AS IT WON'T PRINT PROPERLY INK CARTRIDGE IS NEW AND THREE QUARTERS FULL?
what is your actual problum say clearly . r u useaing orignal print kartridge . keep ur ink kartridge in worm water for some time. and clean its nozel with clean paper then use it
Jun 03, 2008 | Brother Office Equipment & Supplies
Intex "" Metal Frame Pool Set (56998e) 56998e Logo
24 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
