Question about HP Pavilion a775c (A775CB) PC Desktop
No power I shut down my computer last night and it would not power up again. there is a green LED flashing just below the power input on the back of the computer.
  • dcormack Oct 11, 2007
    I tried that. it didn't work. thanks.
  • Anonymous Oct 16, 2008
    I put my computer into hybernation mode and now it will not strat-up; I also have the green led light flashing just below the power cord. I am removing the power plug for ten minutes and then I will try again. Hold-on-- ten minutes are up; still does not start-up.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 141 Answers
You have to try to check all the connection inside your system unit, then try to clean it up and check your bios configuration... Try cleaning the memory and also with the power supply,,, Look for an appropriate power supply..
Posted on Jan 05, 2010
That was next thing i checked, and bingo! dead power supply.
thanks for your help.
Posted on Oct 12, 2007
  • 116 Answers
Did you try removing the power for about 10 minutes, then trying again?
do you get any lights or sounds after trying that?
Posted on Oct 11, 2007
  • Charles Fields
    Charles Fields Oct 11, 2007
    According to all the other users with that problem it winds up being the power supply.
    If you have a local computer shop you can remove the power supply from the machine, and bring it in. They have a small device that can give you a clear answer if its good or not.
    You could always swap it with another if you happen to have one.
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Dec 21, 2008 | E-Machines Emachine T5026 power supply **...
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Green light blinking on back of my system unit but there is no power
I had this problem and i tried everything to make it work. Now all i do is put a hairdryer at the back whilst the computer is plugged in until the light stops flashing then switch on as normal. I also noticed that when the air is warm i do not have to use the hairdryer hopes this helps.
Aug 31, 2008 | Computers & Internet
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
HP Pavilion a775c (A775CB) PC Desktop Logo
139 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
