Question about Sanyo Dp55441 TV
Remove base plate of dp55441
How do I remove the baseplate on the dp55441 so I can install the stand?
    Top Expert:
  • Sanyo Master
  • 75,289 Answers
To know more about this, you have to download the repair manual to this set. Try for it. If you wish to get some information, check the site linked here. It has disassemble procedure to many popular brand TVs, with illustrations. Pull up older posts. Disassemble procedure will have details you want.
Posted on Nov 27, 2013
How do I replace the roller brush on a kirby Heritage II?
The brushroll is held onto that baseplate by the metal brackets on either end of it. You have to slightly bend them outward to remove the brushroll.
Apr 16, 2014 | Kirby Heritage II Vacuum
Ive put a new roller brush in my dyson dc14 now it makes a awful noise
Hi There,
I work as a tech for VacuumSpot and the problem you are describing is pretty common. It generally happens when you replace the belt or roller as the new one isn't worn so is marginally thicker than the old one. Basically what you need to do is remove the base plate and turn the brush roller by hand to make sure it is seated correctly. It is best to then replace the base plate and run it while its upside down so you can see that the roller is turning freely.
THe sound you are hearing is the clutch engaging because the roller is not able to turn freely because it is pressing against the baseplate. Once the roller and belt are able to turn while the baseplate is on the sound will go away.
Apr 06, 2013 | Vacuums
Replacing base plate
The base plate for your saw is held in place by a screw that goes through a plate that fits into the raised part of the baseplate with the elongated holes. The nut that holds the screw in place is sandwiched in the base of the two housing halves. The raised part of the base plate and elongated holes are what allow you to tilt the base plate.
Jun 16, 2012 | Saws
Replacing 5007 baseplate
I hope we're talking about the same nut, is it the one on the lever to lock the cutting depth? If so, it's held in place by a lock plate that you remove by taking out the small pan head screw next to the nut. After you take the lock plate off the nut should come off easily.
May 22, 2012 | Makita 7 1/4" Circular Saw 5007NB
How do I clean the Baseplate
Good day!
The easiest way to clean the base plate of your electric iron is to use a sand paper (P200) p200 is the number of the sand paper that you need to use..
Scrub gently it in the base of iron until the real color of the metal is appear..If the color of the metal is appear it means the metal base plate is cleaned and ready to use..
Thank you and I hope this simple information help you..
Jun 17, 2011 | Philips Irons
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
I cannot find my owner sheet and need to change the belt in my upright oreck
THERE IS A SINGLE SCREW ON THE SIDE OF THE VAC KNOWN AS THE 'BELT DOOR'.
LAY VAC ON IT'S RIGHT SIDE, SO THE BELT DOOR IS STICKING STRAIGHT UP IN THE AIR. REMOVE DOOR AND BELT DOOR. CUT OLD BELT IF IT IS NOT BROKEN. TUCK NEW BELT UNDER BRUHROLL PULLEY FIRST THEN STRECH OVER MOTOR SHAFT.
DO NOT REPLACE BELT BY REMOVING BASEPLATE. 1) THE MOTOR IS NOT STABLE ENOUGH FOR THE TIGHT BELTS WITHOUT THE SUPPORT OF THE MOTOR 2) REPLACING BASEPLATE IMPOPERLY MAKES VACUUMING DIFFICULT. ">
Feb 18, 2011 | Oreck XL21 Bagged Upright Vacuum
How do i remove baseplate
screw on bottom of tv,,right above base plate ,,take the out,,philips screw driver,,lat tv flat on its back ,,
Nov 03, 2010 | Toshiba Televison & Video
Base Plate screw rotating in insert and not coming out. Insert come unfixed with screw still attached. Therefore unable to remove baseplate, unable to remove cotton fibres from brushes. Have you an...
Try to remove all other base plate screws first. If they can be removed gently try to pull open by hand against the lid while rotating the remaining screw. You will need to apply outward pressure betweent the insert and baseplate to remove it while rotating with a driver and using the separating pressure to allow it to unscrew.
The inner housing may have a cap nut on it which has spun loose or the threaded area of the housing has likely cracked if the head has been dropped.
Sep 08, 2009 | Vacuums
Oil filter base plate
it does have an O ring buts its irregularly shaped. it is usually held on by 3 bolts(mine was). and the top most bolt was very close to my oil pressure sensor....(had to take it out to avoid breaking it) i needed a very short ratchet wrench and get it out. Make sure you get the ring from a Honda Dealership if you can.(i have bad luck with aftermarket parts on my Hondas).The reason why mine was spraying is because the baseplate was actually cracked. so i also had to buy a new one ( yes they have them too) O-ring 12.00 bucks baseplate was 39.00 bucks for me, might be a bit more for yours since your Honda is a little newer (mine was an 89 accord) oil filter baseplate or mountplate are some terms (so you were right on) hope this helps.
Mar 08, 2009 | 1993 Honda Accord
Sanyo Dp55441 TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
