I torn it on but in a second automatically torn off the power or shot down.
I don't know where can i started to trouble shot,in the power supply or in the amp.where can i get a schematic diagram for this amp and its test point?...
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
You haven't specified the details about the probelm you faces with this TV. For more information go to http://electronicshelponline.blogspot.com/ Troubleshooting hints to some popular televisions are given in detail. Pull up older posts.
Posted on Nov 27, 2013
4 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: I have a Panasonic TH-42PX80U TV. When I power up
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Oct 04, 2010
SD Tech
  • 14553 Answers
SOURCE: i don't know which is right x-sus & y-sus or power supply 12/22 codes
If they are on left and right sides look from front of set--if not Google the model for a service manual which will have a pictorial showing which is which.
Posted on Jun 13, 2012
SOURCE: schematic diagram for power supplys LG 60PC1D-AA
I do not have the schematic, but have a testing / troubleshooting guide for the 60PC1D 1st and 2nd generation, which gives some good insight in organization and functionality of the power boards.
This is what we ourselves step on when repairing - LG often does not publish schematics for power boards and sustain boards.
contact us if interested
Posted on Sep 30, 2012
Sharp tv shut down after about 2 seconds
Could be power supply trouble. It tries to start but can't and shuts down.
Dec 06, 2013 | Televison & Video
My symponic tv is in standby mode and won't turn on
check for defective regulator at the power supply section and shorted horizontal section. if you don't have an idea how to trouble shot this unit i suggest to leave it to a trained tv repairman to fix the problem. atleast you have an idea what to expect when you hire somebody to do the job good luck.
Sep 17, 2012 | Symphonic ST419E TV
Acaer aspire 7736 z is not powering on
Remove main battery, and try to power up, no change, check power supply for correct voltage, if okay, the DC jack in the laptop is a common source of trouble from no power to intermittent operation. The computer will need to be torn down to address the problem.
Jun 17, 2012 | Acer Computers & Internet
Viewsonic n4251w power supply, no start
Power supply is first place to look:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
May 01, 2012 | ViewSonic Televison & Video
Power problem in intel d865gvhz
Pull cmos cell from motherbord for 10 minutes.
So all motherbord settings defaults.
Then reconnect ATX power supply connector from smps to motherbord.
If still face same issue then you need to change or repair your SMPS.it is in back top side of cpu cabinet.
Try with other smps if still same issue then your motherbord has some issue.
You can trouble shoot this issue with above step follow 1 by 1 .
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Intel D865GVHZ Motherboard
Dell dimension starts up then shuts down
power supply shot
can get power supply from microcenter
http://www.microcenter.com/single_product_results.phtml?product_id=0293459
or take your out REMEMBER where plugs go and buy a new one cheap
Jun 01, 2009 | Dell Dimension 3000 PC Desktop
Insignia TV model NS-LCD26A power up problems
you are correct power pack has bad capacitors, doing what you did may have damaged other components in the power pack, or main video board. let me know what you want to do.
Mar 29, 2009 | Insignia LCDTV26 26 in. Television
Power turns on and off
Sounds like a thermal issue. New power supply might be overheating the cpu causing the thermal sensor in the cpu to automatically shut down so the cpu doesn't fry. You could try adding a case fan or two plus upgrading the spu heatsink/fan. Hope this helps.
Dec 19, 2008 | EliteGroup ECS P4M800-M Socket...
Shot down of laptop
It can be two things. One is the adapter for the power cord in your computer has been damaged and may not fully operate or your power supply has a fault it in somewhere. Test the adapter in your laptop with another similar power supply and if it works you know its the current power supply you have, if not its the adapter and it needs to be replaced and sometimes that can mean a whole new motherboard depending on what brand and model laptop you use.
Hope This Helps
Nov 20, 2008 | HP Pavilion dv4000 Notebook
Power On trouble with Computer
If don't you have any beeps check maybe the power button stack.
If the power button pressed for four seconds then the computer normaly shut down.
Jan 11, 2008 | Abit KV7-V Motherboard
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
