Question about LG 42PX4DR 42 in. Plasma TV
LG 50 inch flat screen tv the picture flicker and black out
Picture flickers and blacks out
  • 92 Answers
SOURCE: 37 inch flat screen LG TV flickers
Take the TV to a local TV Repair shop.
Ask them to check the Inverter and the Power Supply.
Deffinately fixable.
Posted on Sep 06, 2009
  • 8457 Answers
SOURCE: No Picture on a 4 yr old TV
Ur LCD inverter board it dead,need it replaced.
Posted on Nov 20, 2009
  • 302 Answers
SOURCE: LG 50' Flat Screen TV;
A black line down the middle of the TV can be a few things. You plasma panel might be bad your buffer on that location of the screen might be bad or your logic board might be bad. Teh only way to find out is by replacing the parts , You can get parts at www.interliquidparts.com
Posted on Jun 08, 2011
caroldon
  • 17129 Answers
SOURCE: 42" LG Plasma HD Ready
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure.This can be due to faulty capacitors that have gone weak and resumes the value after some time when the cotlage builds up. Also there is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Aug 20, 2011
freetek
  • 5568 Answers
SOURCE: 42" lg lcd tv pitcher flickers then gos black
Since the audio is still working, the main power supply probably
wasn't at fault and you may be looking at more research and possibly
more expense.
The problem is very likely on the largest board or with a failing
circuit that is part of the display.
You may be able to isolate it by using 'freeze spray' which you can
buy anywhere electronic parts are sold.
I suggest more than one can of it; ~ $7-8/can.
You will need to have the guts exposed and the set turned on.
Look around the edge of the display itself for chips (ICs) and give
any you see one brief shot of the spray, wait for ~1 minute for it to
'soak' and then move on to the next one.
If the video comes back, even if only briefly, repeat the cool-down
until you are confident to have found the right one.
If you can isolate it, you still have a problem.
If the sick IC appears to be 'glued' (with solder) onto instead of
through the board, you may not be able to replace it successfully.
If you can see that it has pins going through the board, these can be
replaced by anyone with a professional soldering tool and a steady
hand.
Remember, the problem can be on a board that is only connected to the
display panel but if on the panel itself, you may not be able to buy a
replacement for less money than a new set would cost.
Posted on Nov 10, 2011
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
LG 50" Plasma, getting black flickering screen and no sound
Your TV need a through check up. It will be best to contact any service technician. To get some details, http://electronicshelponline.blogspot.com/Pull up older posts.
Dec 11, 2013 | LG 50PX4DR 50 in. Plasma TV
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
BROKEN SCREEN
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Jan 10, 2013 | Samsung 55" UA55C7000 MULTISYSTEM LED 3D...
I would take it to a repair shop, but it sounds like somewhere in the power board.
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
LG LCD flickers and turns itself off
I'm guessing here.. most probably its the ccfl tubes..
Aug 27, 2009 | LG 37 in. Flat Panel LCD HDTV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Flickering red spots
its due to overheating of any component on the main board and needs to checked with a meter to locate the faulty and replace.
Jan 05, 2009 | Televison & Video
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
LG 42PX4DR 42 in. Plasma TV Logo
24 people viewed this question
Computer Repairing
Computer Repairing
