HP LaserJet M3035 MFP Printer Logo
A
Anonymous Posted on Nov 27, 2013
How do I scan to computer? - HP LaserJet M3035 MFP Printer
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Nov 27, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
465941
Points
5959
I have a HP that i bought when i had my Vista computer the software installed on it fine. For 2 years now i have a new computer that runs win7 The software and drivers don't all install I can't print on cds nor could i scan I discovered later that i can scan but using control panel/devices and printers rightclick your printer and choose scan
1helpful
How do set up my lexmark pro901 to scan to my pc so that I can email the scans
Make sure the Lexmark Pinnacle Pro901 printer driver is installed on your computer. If you have the install disc that came with your printer, just insert it to your computer hard driver and follow the instructions on your computer screen. You can also the download the printer driver from the Lexmark website at http://bit.ly/d3ftso. Select your operating system > download > execute the file. Again, just follow the instructions on your computer screen.
Note: The install disc contains the Lexmark OCR scan software necessary for scanning documents for editing and saving them as PDF files. The downloaded driver does not contain the OCR software.
To scan to your computer using the printer operator panel:
1. From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2. Touch USB-Connected Computer or the name of a network computer. The local or network computer is the destination that will receive the scan. Wait until the printer has finished downloading a list of the scan applications available on the selected computer.
3. Select an application (in your case your email), and then touch Accept.
4. Select the color, resolution quality and the original image size. If necessary, touch Accept each time you make a selection.
5. Press the start button to start scanning. The scan is complete when the application you selected in step 4 opens on the destination computer, and the scan appears within the application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1. Click Start.
2. Click All Programs or Programs, and then select the printer program folder from the list.
3. Select Printer Home.
4. Choose your printer from the printer drop-down list.
5. Click Email, and then select Photo, Document or PDF.
Note: You can select Document only if an OCR application is stored on your computer. Scanning starts and the scan progress dialog appears.
6. When the scan is finished, a new e-mail message is created with the scanned document automatically attached.
7. Compose your e-mail message. Note: If your e-mail program does not open automatically, then you can scan the document to the computer and then send it through e-mail as an attachment.
For Mac:
1. From the Finder desktop, double-click the printer program folder.
2. Double-click the printer Center to open the All-In-One Center.
3. From the "What is being scanned?" menu on the main screen, select a document type.
4. From the "How will the scanned image be used?" menu, choose To be viewed on monitor/web page.
5. From the "Send scanned image to" menu, choose an application.
6. Click Scan.
7. Retrieve the scanned image from the application, and then send it through e-mail as an attachment.
I hope this information has been helpful.
COMPUTER FREEZES WHEN SCANNING
All scanning requires alot of computer resources. You could try reducing the DPI before scanning. This will reduce the quality of the scans but will stop the computer from freezing when scanning.
3helpful
2answers
HP photosmart C5580 How scan to computer?
scanning through bluetooth is not possible bluetooth module only pairs the computer and printer and has link only to the basic driver of the computer so you can only print from it
if you want to scan you should connect te usb cable or use a wireless upgrade kit
9helpful
2answers
What exactly does the word 'scan' mean and what does it do?
"Scan" means the printer can "read" whatever is put on the glass. It can then generate a copy from the printer of what it "scanned/read" or it can save it to a file
2helpful
2answers
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
1helpful
2answers
Hp6280c does not list computer in scan options
Click Here and follow the instructions to add your computer to the scan destination options.
2answers
Scan to computer
perform your scan operation via your PC's start>programs>HP>solution center rather than the printer console
MY HP PHOTOSMART DOES NOT GIVE OPTION TO SCAN TO PC
First make sure that the software is sucessfully installed in you computer and then try the steps metioned bellow.
Go To My computer>C:\Drive\windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:\Drive\windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:\Drive\Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Sending a scanned picture to my computer
Scan an original to a computer
You can scan originals placed on the glass by using the control panel.
To scan to a computer
1.
Load your original print side down on the right front corner of the glass.
2. Press Scan Menu.
3. Press OK to select the default application to receive the scan, or press to select a
different application, and then press OK.
A preview image of the scan appears on your computer, where you can edit it.
4. Make any edits to the preview image, and then click Accept when you are finished.
k24674
Grand Canyon Tech
Grand Canyon Tech
