Question about Aqua Lung Aqualung Calypso/Titan Octopus, Yellow SCUBA Equipment
High pressure fail - Aqua Lung Aqualung Calypso/Titan Octopus, Yellow SCUBA Equipment
Willthe bluebird sss oil pump fail after 20 years
It certainly could.
Also, at that age, the bearings and clearances could be getting slack so oil pressure would be expected to get lower.
If oil pressure is high when engine is cold, and low at idle when engine is hot, and high at higher RPM with hot engine, then it's more likely engine wear than bad oil pump.
Low oil pressure at high rpm with hot engine indicates failed oil pump. Best not to run when you have this condition.
Oct 11, 2015 | Cars & Trucks
Pressure washer failed
What are the symptoms? Water in oil requires changing seals ( probably high and low pressure) Low , fluctuating pressure is probably valves need cleaning or replacement. Low pressure could also be worn unloader. Water leaking from pump is worn high pressure seals. Many possible failures.
Saying pump has failed is like saying my car does not work.
Feb 10, 2014 | Computers & Internet
Code p0191
P0191 FORD - Fuel Rail Pressure Sensor Circuit Range/Performancexicon.jpghttp://engine-codes.com/p0191_ford.htmlForum CodePossible causes- High fuel pressure
- Low fuel pressure
- Damaged FRP sensor
- Excessive resistance in the circuit
- Low or no fuel
- Wiring harness connector of the fuel pressure sensor
- Fuel
- Vacuum leaks
Jul 04, 2012 | 2003 Ford Taurus
What are codes p1249 & p1211
P1211 Injector Control Pressure Sensor Above / Below Desired P1249 Wastegate Control Valve Performance
P1211 We all know that this code is commonly caused by "Hot Chips" that are demanding more Injection Control Pressure (ICP) than the High Pressure Oil Pump can deliver. For what it's worth, these are the exact parameters that trigger this code:
  • ICP 410psi Higher Than Desired for 7 Seconds
  • ICP 280psi Lower Than Desired for 7 Seconds
This code can also be caused by legitimate High Pressure Oil System issues. Below is a list of some of the causes:
  • Failed or Sticking IPR (Injection Pressure Regulator)
  • Failed or Weak HPOP (High Pressure Oil Pump)
  • Any Leak in High Pressure Oil System (o-ring, stuck injector, etc.)
  • Low Fuel Pressure (Rare)
P1249 it is the HPOP, above or below pressure, if you have added a performance chip to your vehicle , you will get this code from time to time, basically its Turbo over boost
Sep 18, 2011 | 2000 Ford F350 Super Duty Super Cab
High oil pressure 80 psi on a jeep wrangler, what could be the cause?
Possible stuck pressure relief in the pump or a defective sending unit. Try putting a container of Marvel oil in there and see if it helps. Also putting a mechanical pressure gauge on it temporarily will give you an idea if the pressure really is that high. if pressure remains that high it can cause the filter to fail and leak. Therefore if you can't find an external cause, then the pump will need to be replaced or you can loose the engine if filter fails.
Jan 01, 2010 | 1997 Jeep Wrangler
Oil pressure gage stuck on high
HI, you will need to replace the oil pressure sending unit(pressure switch), it has failed.
Jun 21, 2009 | 2003 Chevrolet Tahoe
1991 volvo turns over but wont start
If your air mass meter tests good, the I would tell you to check the HIGH PRESSURE PUMP underneath the Driver's side chassis pump holder-next to the fuel filter.
There are 2 pumps on your Volvo---the in-tank low pressure, and the chassis mounted high pressure. The car will run with the in-tank failed and the high pressure good. It will not run with the high pressure failed. Test the pump by applying voltage to the two terminals.
Another common failure, should the high pressure pump be good, is the HALL EFFECT SENSOR located in the distributor on the back of the engine. Once this sensor goes, it's no start. A rebuilt or used distributor may be the answer to your problem.
Mar 20, 2009 | 1991 Volvo 740
High (incoming) water pressure in house
You only have to regulate the incoming valve in your wall (to the washer) to have safe pressure.........don't see any reason why you can't do this.........& get on with your tons.......
Nov 27, 2007 | Kenmore 44102 Front Load Washer
Aqua Lung Aqualung Calypso/Titan Octopus, Yellow SCUBA Equipment Logo
66 people viewed this question
Top Aqua Lung Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Aqua Lung Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
