Question about ASUS P5PE-VM Motherboard
One of the capacitor near the atx socket burned and cannot recognise the value pls. provide me with the exact value of that electrolitic capacitor
  • 2,113 Answers
I don't know your board but one i looked at a few days ago needed 5 3,300 mF
Posted on Nov 27, 2013
  • mikadot
    mikadot Nov 27, 2013
    i was trying to look at closeups of images of the board it is hard to tell
2 Suggested Answers
jomabug76
  • 1148 Answers
SOURCE: Drivers Required lost the cd provided by vender
DOWNLOAD NEW DRIVERS ONLINE
Posted on May 15, 2009
I have sharp tv model 20v-r70m not power on the b+ is ok i try test 9v supply go to ic801 drop the 9v,then i try replace ic801 nothing happen, how to fix this
pls. check if there has 5v ic regulator... also check the open non- electrolytic colored yellow or orange tantallum capacitor near the talc switches and memory ic.if i'm not mistaken.... the capacitor value is 2.2uf 50v.
Jul 14, 2014 | Sharp Televison & Video
My set is having a vertical related problem.When turn it on it displays a good screen and picture but a few seconds there is a folding of screen up and down that starts from the low portion of it..and that...
Hi
Please check the voltage in Vcc pin of the vertical output IC. If it is higher than apropriate voltage, replace the filter capacitor in the DC supply line of the IC. This voltage comes from one of flyback transformer windings so you should look for its rectifier diode and capacitor near the transformer. If this voltage is correct, replace the electrolitic capacitors in the vertical circuit output and some 100/220nF poliester capacitors near the linearity pin of the IC.
Sully
Sep 29, 2013 | RCA Televison & Video
Need to know the exact value of capacitor about msi 848p neo2-v .the capacitor beside processor b'coz i want to replace it since the motherboard is not my hand. somebody know the pls tell me.. th
Hello here is the homepage:
http://www.msi.com/product/mb/848P%20Neo2-V.html#/?div=Manual
The value is printed in on the capasitors.
You can unsolder them but, mark the location where it goes
and remember plus and minus.
This will probably cost the same, as a new mainboard to renew them all.
A electronic repair shop, can order the capasitors for you.
A brand new mainboard, is sold today for around 100 dollars, in a online shop.
Your mainboard has socket lga775, so you don`t need to buy a new cpu, but you probably have to buy a new windows, and ram modules as well.
Good luck
Jan 13, 2013 | MSI 848P Neo2V Intel 848P Socket 775 ATX...
How to troubleshoot vertical, their is a block on the top of screen upper portion.
verticle has very few components a round it. you have said on top of a tv a shadow is appearing. do the following
when you check near the verticle IC there are three or four capacitors, a bigger capacitor one side is connected to an IC the other side is connected to a cable going to a scan coil, a scan coil is that round coil with four cables connected to it on a tube and check for leakages or shorts on the capacitor. thanks.
Jul 01, 2010 | Televison & Video
Audio drivers proble
You donot mention here the exact mother board model no of murcury, But still in giving you one link from where you can download the drivers Here you will find three model no mention below. Pls choose the exact model no. from here to get the exact model no , check *********** board box or bill. if still you you donot get the exact model no . then pls try all three model drivers on by one. One will be right driver. It will not take mch time to try all one by one.
1. KOB KT266a FDSX - AMD K7 (Socket A) Mainboard w/ VIA KT266A
2. KOB KT266a FSX - AMD K7 ATX Mainboard w/ VIA KT266A chipset
3. KOB KT266a FDSUX - AMD K7 (Socket A) Mainboard w/ VIA KT266A
the link is :- http://www.mercury-pc.com/downloads_list.php
Sep 10, 2009 | Mercury Electronics KT266A Motherboard
How do you fix the clock display
No or dim display? You can replace the clock at about $160.00, or Check for a burned capacitor on the clock board, The likely culprit is labeled C3 on the board, its a 35 Volt 68 mF capacitor that needs to be replaced with a high temp (105 degree C) capacitor . Any capacitor that shows signs of discoloration and or leakage should be replaced with the same value but high temp. component. You can use regular capacitors of near equal values in a pinch but find the good ones of the correct values for a long term fix.
Aug 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
Motherboard power problem due to atx 12v cable
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
Jun 09, 2009 | ASUS P5P800-VM Motherboard
Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my...
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
Mar 09, 2009 | Computers & Internet
ASUS A8N-E motherboard dosen't boot up
Make a deep examination of the board, look for burned/broken microresistors. You might need a magnifying glass and good lighting. Any resistor showing a little blob or browning is burned. Microresistors are those minuscule black,gray,brown or white rectangles lying all over the motherboard's traces. Check first the ones near the power supply connector and near the chips, specially one that says winbond on it, this last ones may get burned from USB overloading, from using non-self powered hubs also called passive hubs.
You may check for blown capacitors, capacitors are those standing cylinders with a plastic cover around them with numbers and letters printed in those covers. On top they are left without a cover and they are aluminum color, they may be flat or have one or more grooves runing across the top. A blown capacitor, looks different from the others because it looks a little bloated on the top, or may have spilled some sort of transparent varnish from its bottom to the motherboard or its top to other components around.
After that, you might want to check that your memory is OK in another computer and seated right in your motherboard, check the graphic card if it isn't of the integrated type. Finally you may suspect of the CPU, athlons get very warm and they can get burned too. Never start your pc without a cpu.
Jan 03, 2009 | ASUS A8N-E Motherboard
Problem
My be something wrong with your ATX. It can depend on transistors too. If you have tester you can check all ATX pins.
Sep 07, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
ASUS P5PE-VM Motherboard Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
