Question about Lands Phones
How to use US bought cordless phone to work in India? Model Name : Motorola L603 M
If I need to use Voltage converter (220 to 110V) to make my device to work then do I need to worry about 60 Hz to 50 Hz frequency or the converter takes care of this? Also since I have 3 handsets to connect to the base what is the optimal way to make use of the converter? Do i need to buy 3 converters for making it to work or any other best option available?
    Wolfpack:
    An expert that has 5 followers.
  • 13 Answers
No need to worry about frequency it will take care by voltage converter. you just need a good quality converter. and no need to buy 3 converters for 3 handsets. just buy one converter and one Multiplug or extension cable and connect it to converter's output socket and put your base power supply and other handset's chargers in and you are good to go.
Posted on Nov 27, 2013
Testimonial: "Thanks for the quick help, even i thought of purchasing a extended cable but that looks bit complicated as I need to pull the cable across rooms where I want to keep the handsets :) and also multiplug will make my 3 handsets to place in the same location."
SOURCE: Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Posted on Nov 17, 2007
  • 15 Answers
SOURCE: Cordless Phone
You did record a message on the answerer, didn't you? Mine displayed that until I recorded the outgoing message for the answerer. You do not need any service from your phone provider. The answerer in the base unit simply records the caller's message when you don't answer after a set number of rings. The manual tells you how to name the handset, which is a nice feature if you don't wish to use "unit 1, unit 2, etc".
Posted on Dec 29, 2007
  • 3 Answers
SOURCE: base not able to connect to handset.
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Posted on Mar 23, 2008
leroyal
  • 2120 Answers
SOURCE: How to link 3 same model cordless phones to one base
Only if you have 2 phone lines.
Posted on Nov 06, 2008
  • 43 Answers
SOURCE: Cordless handset phone will not connect to base
A Microprocessor Problem, beyond ecconomical repair.
AL
Posted on Apr 26, 2009
Why am i unable to connect to my motorola L603m and theres no power supply
Contact The point of purchase. The phone should come with a charger. Or you can contact Looking For Help to find a replacement.
Mark
Motorola Support
May 12, 2014 | Motorola Mobility L603m Digital Cordless...
How can I add a 4th handset to my Motorola L603M?
I think you all totally missed the question. The phone set comes with the base and 2 extensions. He is wanting to BUY a 3rd extension for this unit, if I am reading this correctly. I have the same phone set and I have not found anywhere that sells additional handsets. Sorry.
Nov 22, 2012 | Uniden Cordless Phone
Panasonic KX-TGA101S Cordless bought from US not working in Chennai Telephones ,BSN L(India). Can I have the name of Converter which help it work in compatable frequency for caller ID Thanks Ravindran P
There isn't any converter available. The technology used for caller ID is different and the telephone was made for US use. There's no way to change the telephone to make it compatible. You will need to either get a new telephone made for your country, or find an external caller ID display unit.
Jun 26, 2011 | Panasonic KX-TGA101S Cordless Handset
I have bought an Motorola X Cingular from USA but whe i put an airtel sim in INDIA it displays the service provider name but says contact service operator. what shoud i do?
Hello
The problem with this is that hone that work in USA may not work in India.
If you want the phone to work in India, you will need to flash the phone so that it can work with India network service.
I would have ask you to do it your self but you do not have the software that you will use and it is expensive to buy one.
What i will tell you to do is to go to a mtorrola company in India and the problem will be rectify.
Thanks.
Sep 02, 2010 | Motorola Lands Phones
My uniden phone bought in USA does not display called ID thouhgh BSNL has enabled it. My cheap chinese phone was displaying it. Any help?
Caller ID standards are different in India and the USA, so Caller ID function will not work. You need to purchase a converter which converts from DTMF to Bell FSK standard.
Source
Good Luck!!!!!!!!!!
Oct 18, 2009 | Uniden DECT 6.0 Cordless Telephone...
Model purchased in USA and installed in India. Caller id is subscribed and other phones shows the calling number but this phone KX-TG6431 does not
Only stupids buy cordless phone from USA. India uses ETSI DTMF standard for Caller ID which is not supported by any cordless phone sold in USA. It is about time you trash your worthless instrument in the dumpster.
Jun 06, 2009 | Motorola Mobility 5.8 GHz Digital Cordless...
Will Uniden 2085 DECT phone work in india
The phone will not work with 220 V. And as an FYI, taking the unit out of the country will void your warranty.
Apr 01, 2009 | Uniden 5.8GHz Cordless Phone
The id caller is not working in that cordless phone
Any Caller Id phone bought in USA will not show the id as the Caller id format in USA is FSK and in India it is DTMF. You need a caller id converter from DTMF to FSK. It is available online on www.ebay.in Just type DTMF to FSK converter and the item will be displayed. Right now it is avilable only with a seller in Bangalore and the price is Rs.589/- per piece. I bought it and it is working fine.
Aug 24, 2008 | Panasonic KX-TG1100 Cordless Phone
Caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Jan 05, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Lands Phones Logo
273 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
