Question about Dell UltraSharp 2709W LCD Monitor
My Dell 2709 get off after working for 2-3 hours. & blue power led gets flashing.
    Champion:
  • 219 Answers
Its getting hot use canned air to blow it out
Posted on Nov 27, 2013
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Dell E173FP power led orange/flashing failure returns
First, you can get the service manual here: http://elektrotanya.com/
If the transistors failed again, yes the 0.22uf (part of tuned circuits for the inverter transformer oscillator circuits) changed value, the frequency will be off and causes over heat on the transistors due to too much current draw, You can also have bad inverter transformer, you can check the DC Ohm value but if it has one short turn, it will not show up on DC Ohm test, you have to use ringer testing (I use SENCORE LC75).
http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 29, 2010
Dell 1800 mp
Hi, This may be telling you that the lamp needs replacing. Have a look at the specifications of your projector and note the operating hours of the led lamp. Work out how many hours you have used it for providing it is a Dell part. equivalent parts may have a shorter life. If the led is flashing orange there is a stock fault of a 3300 micro farad capacitor fault in the power supply. Search other reports for this same error.
Do not buy another lamps until you know it is faulty or past its useful life.
These cost about 99 each. Tim
Aug 22, 2014 | Dell 1800MP Projector
Dell 2709 LCD gets off.
It is getting hot. Use canned air to blow it out.
Nov 27, 2013 | Dell UltraSharp 2709W LCD Monitor
Dell battery alternate led flashing
How old is the battery? Is it a replacement? My batteries usually last 4 years, more or less.
Nov 15, 2012 | Dell Latitude D530 Notebook
I have a Dell Precision 490, the Light at 1,3 and the power button blinks and i cannot star tmy computer!
I normally post this link:
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
but I think I can get better info for you here:
http://support.dell.com/support/edocs/systems/ws490/en/ug/tools.htm#wp1057769
2 things.
The power led flashing amber can mean a failure of one rail in the power supply, or a bad connection (The cables are removable from the power supply) so you may try reseating power connections internally.
1 & 3 LEDs can mean a RAM failure
Aug 22, 2011 | Dell Precision Workstation 490 - MT -...
I’m having a problem with my Toshiba 42HL196. Once or twice the red LED was flashing and I held the power button in for a bit and it started working again. Today I was having cable installed and after a...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 13, 2017 | Toshiba 42HL196 42 in. LCD HDTV
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Just hooked up mtx 500d mono amp and 12 inch sub worked for a 1/2 hour then sub quite and led on top of amp just flashes.
Your amp went in to power protect. You must adjust the settings on amp. This is usually very time consuming to get it right. Good Luck
Mar 24, 2010 | Car Audio & Video
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
DELL COMPUTER WOUN'T START
1. Ensure that the power supply is working
2. If yes then make sure all connections are properly connected
3. If No,you will need to buy a new one
Jul 12, 2008 | Dell Computers & Internet
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Dell UltraSharp 2709W LCD Monitor Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
