Question about HP Officejet 5610 All-In-One InkJet Printer
Paper jam but no paoer jam
I've remove the paper jam cleaned the HP Printer turned it off na dback on and it still tells me there is a paper jam
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
SOURCE: paper jam HP Laserjet 3050z
Open tray 1 and pull any visible jammed media out of the all-in-one.
If no media is visible, open the print-cartridge door, remove the print cartridge, and rotate the
upper media guide. Carefully pull the media up and out of the all-in-one.
Close tray 1.
Posted on May 04, 2009
FixinFax
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
  • 224 Answers
SOURCE: HP Laserjet 4345 mfp paper jam.
recycle the power to reset
Posted on Mar 31, 2010
How to clear a paper jam in my printer?
  1. Turn off the machine, and unplug the power cord of the machine from the power supply.
  2. Open the paper output cover. ...
  3. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  4. Hold the jammed paper with your hands.
  5. Pull the paper slowly not to tear it, then pull the paper out.
to know info SAF 2507 pipe fittings
May 20, 2016 | HP PSC 950 All-In-One InkJet Printer
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
I hav3 hp 1005 printer and its continuously jamming papers..pls tell me solution of this problem
The paper jamb could be caused by dirty or sticky rollers or failure to remove all traces of paper from a previous paper jamb.
Check for tiny pieces of paper in the printer, remove these pieces of paper.
Try cleaning the rollers with methylated spirits.
Apr 29, 2011 | HP LASERJET P1005 Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer is showing E3 and there is no paper jam. How do I correct this so my printer will print
mp140/145 e3 error paper jam but no paper ,in my experience ,nag karoon nga ng paper jam at wala na ang papel pero still E3 pa rin !!!!!! ----na dis align yung sensor padel na tuwing tatamaan ng papel na syang swits on/off (example) sa pag pasok at labas ng papel
Nov 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Had paper jam, removed paper. Now it keeps telling me that it has jam paper still. There is no paper that is jam. Is there any type of reset button?
HP is a terrific printer. Try cancelling the print request in the computer, turning off the computer,then unplugging the printer, giving them a few minutes to re-set, then, then turn them on again. Also, look for a small, torn piece of paper within the printer, in case it is causing the issue. Best of luck.
Apr 11, 2010 | HP PSC 750 All-In-One InkJet Printer
My hp 3940 had a jam. I removed the paper now it
Hello there
i know you have cleared the jam but i would go back and really look closley at the paper path and the internals a small piece off of a paper can cause this to claim it has a jam also if you turn off the printer and use canned air to blow out the whole insides this will help too also clean offf any lenses with a eyeglass cleaner ok ?
best regards mike
Aug 06, 2009 | HP DeskJet 3940 InkJet Photo Printer
My hp 1315 all in one had paper jam
1. Remove any loose paper
a. remove any loose paper from the In tray and Out tray
b. press the cancel button (x) on the product control panel to clear the paper jam
2. Clear the jam from the back of the printer
a. press the Power button to turn off the product
b. unplug the power cord from the back of the product
c. remove the rear access door. turn the knob one quarter turn to the left, and then pull the door away from the product
d. gently remove the paper
3. Clean the rollers with a lint free cloth that is moist with water
4. Try printing again
Aug 07, 2008 | HP DeskJet 5652 InkJet Printer
Clearing paper jam
Solution Use the following instructions to clear a paper jam from the HP All-in-One.
  1. Press in the tab on the rear clean-out door to remove the door. CAUTION: Clearing a paper jam from the top or front of the HP All-in-One can damage the print mechanism. Whenever possible, access and clear paper jams through the rear clean-out door. Figure 1: Pressing the tab and opening the rear clean-out door c00444711.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the HP All-in-One. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are might occur.
  3. Replace the rear clean-out door and gently push it forward until it snaps into place.
  4. On the HP All-in-One control panel, press OK to continue the current job. NOTE: If the paper is still jammed, see the onscreen Troubleshooting Help that came with the HP Image Zone software.
  5. If the jam occurs again, check to make sure the paper type in the printer matches the paper type set in the printer driver properties
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
187 people viewed this question
Seeker5211
Seeker5211
