Question about NetGear RangeMax 240 WPNT121 (WPNT121NA) 802.11g/b Wireless Adapter
Cant connect hiya i,m having trouble with my wireless, the router picks up the modem and my laptop gets a good strength signal but i cant get into the router setup or on the net with it desperately need help here cheers roger
  • King826 Mar 05, 2008
    i have similar problems, i'm using rangemax router and a rangemax usb 2.0 adapter wpnt121 for my other pc. the problem is i can't connect to the internet even tho i properly install everything. It seems that i can't connect to other outside unsecured networks too. But it detect in range networks but cannot connect. WEIRD HELPP!! but then, my laptop is able to connect to my rangemax router....
    hmm must be the adapter.....
  • AnthonyArndt Oct 11, 2008
    I have the same trouble as King826. All settings are correct according to the the wizard, the manual, and Netgear's on-line KB. All firmware and software is up-to-date. I've tried configuring with the wizard and manually. My computer with the WPNT121 Adapter can connect to my neighbor's network two floors down (he has a Netgear router) but not my own (in the next room).
    I am beginning to suspect that while Netgear's routers are great. Their USB adapters are substandard and only trully compatible with their own routers. Had I known, I would not have bought networking equipemnt from Netgear (I bought my adapter when I bought my neighbor his router and set up his home network).
    Genius:
  • 1,601 Answers
Roger Dodger.. Make sure that your securitycant connect - 1.gif password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
Posted on Jan 14, 2008
SOURCE:
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
I have the belkin router in my home and one of my laptops are not picking up the signal for the router
Probably the Router signal strength is low.
You need to open the EWS page ( Router configuration page ) and increase the signal strength to 11 ( it must be Auto or 1,2,3, etc )
EWS Page ( Router page ) can be opened using the Router IP Address which may be 192.168.1.1 or if you know it. Open Internet Explorer and enter the ip address and hit enter ( without www or .com )
Under Wireless configuration or settings you will find the Channel Strength. You need to restart your Laptop to get connected again to the network after saving the settings are you will loose the internet connection.
Regards,
Shawn
Feb 01, 2011 | Acer Computers & Internet
My icon says I only have 80% signal strength, is
80% is a good signal strength....but if you want to increase the signal strength, then you need to move the wireless router to a very ventilated area, also the router should be placed atleast 5 feet away from other electronic devices like, modem, ups, microwave ovens,refrigerators etc.... also there should be a line of sight between the router and the wi-fi adapter... but in order to connect to a wireless network 25% of signal strength is enough....
Apr 17, 2010 | Belkin Computers & Internet
Connect another laptop using Vista operation system to my wireless network
thank u for the clarification..if it says "low signal strength" then u will have to reduce the distance between the laptop and the wireless router..also please ensure there are no big objects,walls etc between the two..u can get better signal strength by doing these..also other nearby wireless networks and cordless phones can hamper with signal..hope it helps!regards!
Nov 02, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless not working
Yes, There could be alot of things that are causing your Operating System to not obtain signal from your Wireless Router....I would first of all try troubleshooting this by;;
1st - Unplug your High-Speed Internet Modem and Wireless Router for 30 seconds apprx.
2nd - Restart your Computer.
3rd - Once your computer is logged in and at desktop, Plug-In your High-Speed Modem then wait until all lights appear that show your Modem is online then plug-in your Wireless Router then wait about 30 seconds then try to connect to your Wireless Connection.
If these do not work make sure that, you do not have your Wireless Router. I would also recommend that a way to create and obtain a signal strength that the computer can reach please go to the following website http://www.mythings.com/tips/1664/Where-to-Put-Your-Wireless-Router This should assist you with making a stronger signal strength.
Oct 25, 2008 | Computers & Internet
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Signal strength very low. Belkin ADSL2 modem with wireless g router F 507632-4
signal is bouncing off doors and walls to get to your comp
move comp closer to modem if it increases and your signal strength increases then you know youll have to be close to modem
other problem someone taped your signal and it working off of it call your provider to come out test the wireless signal strength and or password your wireless router settings so some one cant interfere with signal
i dont like wireless myself in the home i go straight cable with ether net cord this always has strenght and cannot be tapped
May 09, 2008 | Computers & Internet
Laptop not seeing my wireless router
ask a neighbor if they pick up our router signal if not start from scrach if it still dont work hope our router on warranty. cheers
Jan 13, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Open Questions:
See all NetGear RangeMax 240 WPNT121 (WPNT121NA) Questions
NetGear RangeMax  240 WPNT121 (WPNT121NA) 802.11g/b Wireless Adapter Logo
133 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
