Question about Electrical Supplies
Clark tm15 error code 78 - Electrical Supplies
2 Suggested Answers
  • 9 Answers
SOURCE: tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
Posted on Jan 24, 2011
Does this answer pm error code 78 apply to a 1999 Dodge Dakota also
it applies to all common rail diesel pumps
( fault codes is p0088/78 also P1229/78
www.baileysdiesel.com for more information
Dec 13, 2017 | Dodge Cars & Trucks
I am looking for an owners manual on an old clark forklift. I was wondering if you can help me
Frequently Asked Questions about Products Manufactured and Sold by the Clark Material Handling Company
Where can I get operator's manuals, parts and service literature, and parts for my Clark lift truck or other Clark Material Handling Company product?
Operator's manuals, parts and service literature, and genuine Clark service parts for your Clark lift truck are available from your Clark dealer. Please be prepared to provide the complete Clark serial number to your Clark dealer when ordering service literature and parts.
How can I locate my nearest Clark dealer?
For the Clark dealer nearest you, please go to our web site at
http://www.clarkmhc.com
and click on "The Dealers," and then click "Look-up Dealer " Then enter your zip code and hit "Find DLR." The Clark dealer servicing
your area will be displayed.
How old is my Clark lift truck or other Clark Material Handling Company product?
Date of shipment information is available by sending an e-mail request to webmaster@clarkmhc.com. Please provide the complete serial number of the Clark lift truck or other Clark Material Handling Company product.
Where can I find the Clark serial number on my Clark lift truck or other Clark Material Handling Company product?
The Clark serial number is stamped into the serial number plate, which is usually located in the operator's compartment. If the serial number plate is missing or illegible, you can find the serial number stamped into the frame. On a Clark lift truck, this will usually be beneath the step into the operator's compartment and may be either on the left or right side of the lift truck. Note:Rubbing the flat side of a piece of school chalk over the stamping may make the serial number more legible.
Can I still get an operator's, parts, or service manual for my old Clark lift truck or other Clark Material Handling Company product?
Photo copies of Clark operator's, parts, and service manuals are
available for many old Clark lift trucks and other Clark Material Handling Company products. Please send an e-mail request to
webmaster@clarkmhc.com for manual numbers and availability. Please provide the complete Clark serial number. Please know, however, that all Clark operator's, parts, and service manuals must be ordered from your Clark dealer
Sep 18, 2013 | Washing Machines
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
Mfc 8480dn error code 78
error code 78 is a fuser error. You will need to replace the fuser with a new one.
May 04, 2011 | Brother MFC-8480DN All-In-One Laser...
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
How do I fix a machine error 78 on my brother MFC 8300?
unfortunately that specific error is pointing to a problem with the thermistor. here is the error code from Brother:78 Heater thermistor harness disconnected or broken. - SOLUTION: REPLACE FUSER UNIT
HERE is a link to other error codes and possible solutions.
Aug 30, 2010 | Brother MFC 8300 Laser Printer
Tm 20 clark forklift error code -46 what does it
Jun 21, 2010 | Clark Forklift Horn Button Switch , Cat...
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Electrical Supplies Logo
61 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
