Question about Pyle P3001at 2Channel Amplifier
Speaker output not working on my Pyle Pro 3001 at amplifier.
Speaker output not working on Pyle Pro P3001at. Is this something that can be repaired at home or will it require profession repair? Does it need a fuse? Everything else appears to be functioning okay.
Why is there no sound output from the speaker?
Check the speaker winding for continuity. If that checks out then obviously no power is getting to the speaker. Check wiring to speaker - if it is ok then there may be a problem with the amplifier driving the unit.
Mar 20, 2015 | Pyle Audio Players & Recorders
Pyle troubleshooting
probably something wrong with speaker
Sep 08, 2014 | Pyle Pro PPHP106A Powered Two-Way PA...
Fuse Type ?? Had a Speaker Cord Short out and Took out the Fuse....Can't Read the Little Glass Fuse
I am having the same problem but mine did not come with a fuse and I can't get a hold of Pyle.
Apr 10, 2014 | Pyle PRO PMX602M 6-Channel 600 Watts...
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
How to fix pyle p3001at humming when master volume at zero
Chances are this is caused by the big electrolytic capacitors in the power supply. They filter out the 50 to 60Hz hum in mains electricity. When they fail it gets in!
Apr 08, 2011 | Pyle P3001at 2Channel Amplifier
We have our power supplies. THe problem is hooking up my speaker to the amp from the radio to the amp to the speakers. What is the connections?
first u need a set of RCA cables,u can pick them up at any car audio shop, plug them into the audio outputs on the back of the radio,run the other to the audio inputs on your amp,from there jus plug the speaker wire into the speaker output on amp then to your speakers.
Jul 18, 2010 | Pyle PLA2200 Car Audio Amplifier
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
I have a Pyle Pro 2000 (have had for over 2 years). This past weekend I lost my right speaker (could hear extremely faint in background). Have it mounted in a metal dolly (the type used in school rooms)...
it could be something else. it could be the speaker itself. you should try to switch the speakers and be sure that the problem follows the amp channel in question.
if it was the mono/stereo switch some contact cleaner could clear that up.
ofcourse, the bad news is that these amps fail from time to time and the cost to repair far outweighs the cost to replace with something new.
Sep 18, 2009 | Audio Players & Recorders
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Pyle P3001at 2Channel Amplifier Logo
66 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
