Question about Sony VPL PX40 Multimedia Projector
Whole unit projector LCD panel with prism for Sony VPL px40
SOURCE: Sony LCD Projector - burned prisms
I have the same projector, but my problem is with red.
A replacement prism assembly is about $2k.
If you can get your hands on another projector for cheap, that's your only hope. You can swap out the blue lcd panel from your prism with someone else... it's a bit of mucking around, but worth it of you can.
Posted on Feb 27, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
  • 75 Answers
SOURCE: sony svga vpl cs1 projector horizontal roll
first of all open the projector and clean it form a bursh then cheack a losing if stips and jumpers thats it
Posted on Apr 24, 2010
welcomejee
  • 10594 Answers
SOURCE: need to reset the lamp hours on a sony vpl px40
Projector should be in Standby mode
Press RESET, <=, => and Enter keys to reset lamp timer.
That procedure is also mentioned in user manual page-39
Thanks.
Posted on Aug 25, 2010
Noticed a yellow hue in the centre of the image projected by BOTH of my second-hand Sony VPL PX40's.
Bit of a common problem with Sony projectors of the era that they often had problems with fading and/or cracking of one or more the LCD panels - especially the blue ones for some reason, leading to the type of problem you are experiencing. No point in swapping components either as they will both have similar faults - although replacing an LCD in a video projector is almost impossible without the manufacturers jigs to mechanically align them afterwards anyway...
Mar 25, 2014 | Sony VPL PX40 Multimedia Projector
How do I take apart a px40 projector?
1,remove the screws on the back. (only 1-2 screws)
2,force the cover(white) from the back
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 06, 2014 | Sony VPL PX40 Multimedia Projector
Sony VPL PX40 Multimedia Projector change lamp -
Hello
The Lamp Model number to your Sony projector is [LMP-P260]. to replace the almp, proceedings are there on page (38) of its user manual. If you haven't its user manual with you now, send your email address to me by Fixya comment box. I've the user manual to your projector in PDF format, and I'll send a copy of it to you by return mail. OK.
Feb 07, 2012 | Sony VPL PX40 Multimedia Projector
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
How do you reset the lamp timer for the Sony VPL-PX40 projector
press the following buttons on the control panel in less than five seconds. RESET, LEFT ARROW, RIGHT ARROW, ENTER
Sep 03, 2010 | Sony VPL PX40 Multimedia Projector
HOW DO YOU PUT THE SYSTEM IN STAND BY
Turn Power Off by pressing power button on projector, it is now in standby.
If projector is plugged in but not in power On mode or not showing picture, it calls standby.
Aug 27, 2010 | Sony VPL PX40 Multimedia Projector
I have two Sony PX11 projectors, one with a bad (discolored prism). How can I pull the prism out to replace it?
it's not the prism. chancs are it's the light filter(s) on the lcd panels. the prism is just coated glass. the light filters determine the color. you need to take the top off, the main board off (unplugging the ribbon cables), and the lens off. the lcd panels anf the filters are attached to the prism. remove the filters, but do not remove the lcd panels!
Aug 14, 2009 | Sony VPL PX11 Multimedia Projector
Blue Haze on screen Sony cineza vpl-hs50 projector
Its your blue polarizer going bad. This happens over time due to the excessive heat generated in the projector. The main problem is that your projector has organic LCD panels that degrade over time and in turn degrades your blue polarizer. The same thing happened to my sanyo Z2. It took 5 years for it to show on my Sanyo because I only use the projector for sports and movies. not daily tv watching. In any case, it isnt worth it to spend the money ti fix it...jut put tat towrds a new projector. The latest crop of LCD projectors almost all use in-organic LCD panels that last much longer. Hope this helps.
Aug 03, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Nov 20, 2008 | Sony VPL PX31 Multimedia Projector
Blue glare
HI there
This might only be a dusty lens on the inside. But it could also be a faulty Mainboard or LCD's.
Take it to a Service Centre and ask them to check it out for you. They normally quote first and then repair if you give them a go-ahead , you've got nothing to lose.
Apr 15, 2008 | Sony VPL PX40 Multimedia Projector
Sony VPL PX40 Multimedia Projector Logo
48 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
