Question about Konica Minolta Office Equipment & Supplies
How to change the Developer in konica minolta bizhub 500 photocopier
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Posted on Aug 23, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How to replace developer in konica minolta bizhub 500
First service mode to clear the counter, then remove the developer section, dump old developer replace with new developer then run TCR adjustment. recommend replacing the drum and cleaning blade at same time.
Nov 25, 2016 | Konica Minolta Bizhub 500...
Please guide me what is the problem and how can I change the developer of the Bizhub 500 B&W Photocopier.
Hi
There is a very good summary list of all the error codes for your machine, which you may find useful, here:
Error Codes Konica Minolta bizhub 500
My main reason for giving you this link is that you cam get a service manual here for a very reasonable cost which should give you step-by-step instructions and diagrams for the change you want to do.
Good Luck
Jan 13, 2015 | Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
How do l adjust ATDC gain on bizhub 500
You cannot manually adjust the ATDC gain in bizhub 500. Replace the developer and execute TCR sensor adjustment in service mode.
Mar 19, 2014 | Konica Minolta Bizhub 500...
Error code c2703 konica minolta c6500 will not start
Please chalk The Developer tank there nite be short in developer
Dec 29, 2012 | Konica Minolta Bizhub 500...
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
How to fix error c0f32 in konica minolta bizhub 180
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Mar 24, 2010 | Konica Minolta bizhub 180 All-In-One...
Konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
May 19, 2009 | Konica Minolta bizhub C250 All-In-One...
46 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
