Question about Denso 1991 Jeep Cherokee Sport 4.0L Remanufactured Alternator
Not sure what hand belt i need
I'm not sure what hand serpentine belt i need for my jeep. When i go to the part store they ask if i need a left or right hand belt. I'm not sure what to get. I do know that on the diagram under the hood is a 299 if that helps.
    Genius:
  • 1,198 Answers
Are there two belts on the motor? Usually the belts are designated:alternator, water pump, power steering pump, etc. Have them show you a picture of your motor to see what they are talking about.
Posted on Nov 28, 2013
Replace the alternator in a 2007 jeep compass limited
First..,Get new part and also a new belt if belt has never been changed..Make sure part is correct,Use safety glasses..Be sure engine is cold..,Notice sticker under hood that shows belt routing diagram..If there isn't a sticker you can hand draw your own..Disconnect battery ground cable..Remove serpentine belt..If you have never replaced a serpentine belt it will get you confused but it is VERY EASY..It should have a diagram of how it is removed on the sticker showing the belt..The salesman at the parts store can show you easier than I can tell you..After removing belt ..,inspect all pulleys for tightness or any type of wobble..Look for any small shines of metal fragments around pulleys..Spin pulleys to make sure they don't have a worn bearing noise and they spin freely......If one seems damaged now is the time to replace it...remove wiring from alternator carefully..Remove alternator mounting bolts..Use a small pry bar or large flat screwdriver to pry the alternator carefully at both sides upward to remove it..It has a small bushing inside of the lower mounting holes which slides in and out to help keep alternator in position.The old alternator is to be turned in to parts store for a core credit so try not to damage it....Lube mounting holes of new alternator so it will slide into place smoothly..Install bolts and get them all hand tight then snug each bolt lightly until they are all seated then torque each bolt..Torque tight but DONT OVER TIGHTEN..It should be no more than 40lbs.torque..carefully connect alternator wiring..Install new belt..Doublecheck everything..,remove all tools from under hood..Coonect battery and start engine for safety check...
Feb 22, 2015 | 2007 Jeep Compass Limited
Please, I need to know the zize to serpentine for grand cherokee 94 with air condicioned.
All you have to do, is go to the auto parts
store and buy a belt
They will give you the correct one,
after you provide all the info they will
ask you
May 25, 2011 | Jeep Grand Cherokee Cars & Trucks
What length serpentine 8 rib belt goes on a 2001 jeep grand cherokee 3.1 td rhd
Not recommended to measure the serpentine belt...as to many variables...Your local Auto parts store should have your needed replacement in stock...best to be perfect on the dimensions...:) Your Make, Model, and engine are all the specs the Parts Team needs...:) Hope this helps.
Jan 03, 2011 | 2001 Jeep Grand Cherokee
What belt do I purchase for a 2002 jeep grand Cherokee 6 cylinder
this vehicle should have only one drive belt just ask at any reputable autoparts store for a serpentine drive belt for a 02 jeep grand cherokee with a i assume a 4.0
Sep 21, 2010 | 2002 Jeep Grand Cherokee
Replace a serpentine belt correctly
if no sticker under the hood to show the route. go to the auto parts store and ask for a belt diagram. if the don't help, try your local repair shop. best of luck.
Aug 06, 2009 | 1994 Jeep Grand Cherokee
How do i change a Timing Belt Tensioner on a 1995 jeep grand cherokee v8 5.2 my belt burned in 2 it and i need 2 take it off n replace it
You really need a repair manual for your model. Most Auto parts stores carry these. However, If your timing belt has been broken (burnt) while the vehicle was running, then you'll need to check for bent valves or cracked pistons. If you are not one, you may need a mechanic.
Jun 01, 2009 | 1995 Jeep Grand Cherokee
Replacing water pump on a 1993 jeep grand cherokee
are you sure its water pump? it kind of sounds like your not sure. is there any visable leaks? if no leaks, that noise you hear could be that idler pulley your talking about. what you need to do is loosen the belt(witch there should be a spring loaded tennioner pully that you got to move to get belt off) once you get belt off spin all pulleys that the belt runs on and see if there noisey, or excessively loose, even fan blade, if fan blade moves alot back and forth than its time to replace water pump( fan is bolted to water pump),( it will move a little thats normal) i'am betting its not the pump, its most likely one of them idler pulleys. now if you need a belt routing diagram, advance auto, autozone, or any other major auto parts stores have web sites you can go on to get one, or you can get one from your local auto parts store, sense you will have to go there for a part any how. if you need anymore help just ask, i'll help you as much as i can. good luck. OLD SCHOOL.
Jan 21, 2009 | 1993 Jeep Grand Cherokee
Denso 1991 Jeep Cherokee Sport 4.0L Remanufactured Alternator Logo
Top Denso Electrical Supplies Experts
Jude24
Lawrence Oravetz
ray012965
Are you a Denso Electrical Supply Expert? Answer questions, earn points and help others
